Macintosh Pascal, Some Highlights.
Subject: Macintosh Pascal, Some Highlights.
Date: Tue, 9-Oct-84 01:10:16 EDT
Article-I.D.: uw-beave.1838
Posted: Tue Oct 9 01:10:16 1984
Date-Received: Thu, 4-Oct-84 04:01:41 EDT
Lines: 147
As promised, here are some of the highlights of Macintosh Pascal.
Most of the following is taken from the Macintosh Pascal Technical Appendix,
which is supplied with the system.
The Macintosh Pascal system package contains the following:
2 Macintosh Pascal System disks, COPY PROTECTED.
1 Macintosh Pascal User's Guide.
1 Macintosh Pascal Reference Guide.
1 Macintosh Pascal Technical Appendix.
The two systems disks are identical, they contain a complete FINDER, with
the minimal font set, the SYSTEM file and IMAGEWRITER. MacPascal itself
occupies a 117Kb file, and contains Pascal, and all the libraries (more on this
later), stored as resources.
There are a number of folders containing all sorts of nifty stuff.
Info Folder:
Contains an Errata file, some hints, and misc. stuff on
working with Pascal
Tools Folder:
o Contains an editor (in MacPascal) that is very close to being
Cary Clark's FILE program. This *CAN* be used to edit your
programs, although this can be done from Pascal itself.
o A file called BROWSER (also in Pascal), which lets you
browse through files, its sort of like ''more''.
o A utility that called something like printfile, that lets
you print and arbitryay text file.
Demos Folder:
This folder contains may slick demos, which I won't describe (save one)
as this would kill half of your fun when you get Pascal..
The one demo to take a close look at is called FLAG, and shows you
just how fast quickdraw REALLY is. I'll say this, it moves soooo
fast, you'll see ''snow'' on your Macintosh's screen.
Now, more on Pascal ITSELF:
According to the manual (Technical Appendix),....
"Macintosh Pascal complies with the requirements of ANSI/IEEE770x3.97-1983,
with the following exceptions:
o In ANS Pascal, the special symbol @ is an alternative representation
for the special symbol ^, and is required to be treated identically
to ^ wherever it appears. In Macintosh Pascal the special symbol @
is an operation and never treated identicall to ^.
o In ANS Pascal,identifiers may be of any length and all characters are
significant. In Macintosh Pascal, all characters are in identifiers
are significant, but the largest identifier is restricted to 255
characters.
o In ANS Pascal, a character-string of length 1 is a char-type value
and a character-string of length n is a value of packed-string-type
(a PACKED ARRAY [1..n] of CHAR -- referred to as a string-type in ANS
PASCAL) with n components. In Macintosh Pascal, all quoted character
strings are string-type values. However, the compatibility and
assignment-compatibility rules in Macintosh Pascal make its behaviour
with respect to character-strings compatible with ANS Pascal.
o In ANS Pascal, no statements that THREATEN the values of a control
variable of a for-statement are allowed. In Macintosh Pascal,
this restriction is not as severe: no statement may ALTER the value
of the control variable of a for-statement while the for-statement
is executing.
o In Macintosh Pascal, only the standard file variable INPUT and OUTPUT
are allowed as program parameters."
The following are SOME of the extensions to ANSI Pascal, (the list is two pages
long...):
o The following are reserved words in Macintosh Pascal:
uses - calls in libraries.
otherwise - the drop through clause of a case-statement.
string - String type.
o An identifier may have an underscore anywhere following the initial
letter of the identifier.
o Macintosh Pascal supports the additional integer-type LONGINT and
the additional real-types DOUBLE, EXTENDED and COMPUTATIONAL.
(The latter are for use mainly with the interface to SANE -dhms)
For the most part, Macintosh Pascal is compatible with LsaPascal, the
restrinctions are mostly on LisaSpecific things, and to fix incompat-
ibilities with ANS Pascal and bugs/quirks in LisaPascal.
Now for the really Cool stuff.
The rest of the Macintosh Pascal Technical Appendix is dedicated to the
QUICKDRAW and SANE Libraries. The Sane and Quickdraw manuals are here, from
what I can tell, in their entirety. There are complete indstructions on
how to call/use/abuse these libraries from pascal, etc.
One of the best features of all in Macintosh Pascal, is its ability to
call toolbox routines directly. There is an "inlines" feature which
lests you define a toolbox trap, and then you can call it as you would
from assembly. There are big, boldfaced caveats about using these though,
as all of Pascal checking (etc) are turned off when you do this. I think
that they really want you to use them, as the demo editor is written
entirely with them. This editor created its OWN menubars with them, etc, etc.
When editing a program in pascal itself, all sorts of neat things happen.
When you end a statement, by entering a semicolon, it is instantly parsed, all
reserved words are highlighted, and the Mac lets you know if it found any
mistakes ( it keeps quiet if none were found). You can invoke the syntax
checker from the menu bar, and it will give you a thumbs down icon when it
finds bogus code. There is a facility for inserting little stop signs wherever
yuo want to put breakpoints. There is also a GREAT menu selection that
lets you watch variables change and another, called INSTANT..., that lets you
execute a statement "instantly".
One of the really cute things, that give you an idea of how much work the
folks at Apple & Think Tech. put into this is, that when entering comments,
if you hit a RETURN, with out closing the comment on that line, the Mac
will supply the closing curly-bracket, making for block structured comments.
Code is also indents for you to the apporp. levels.
My first impressions are good, its a good, pretty fast system.
Its is a great learning tool, and the fact that its mostly compatible with
Lisa Pascal, is noce so you can use a local lisa to write ""real""
applications.
Well, that's a short overview.....if any one has really specific questions,
I'll try and answer them, and if enough intertest I'll post a summary to
the net.
David.
NYU/acf Systems Group
