MacTERMINAL & control-chars (generalization)
Post by Info-Mac » November 28th, 1984, 11:53 pm
Subject: MacTERMINAL & control-chars (generalization)
Date: Thu, 25-Oct-84 22:11:35 EDT
Article-I.D.: uw-beave.2029
Posted: Thu Oct 25 22:11:35 1984
Date-Received: Fri, 26-Oct-84 09:32:40 EDT
Lines: 62
[ with permission, I repost a reply I received from a fellow-ARPAnaut.
I believe that there may be others, who might consider this a gem and
learn one or the other new detail. Hope those that find 'nothing new'
in it will endure for the benefit of the "rest of us" - no discussion
or hype about keyboard-problems is desired or solicited. Werner ]
Subject: A: MacTERMINAL, EMACS, and ^@ (CMD-SHFT-2)
Werner-
Glad you got the practical answers to your question; here's the
theoretical answer:
>> There is no control-~ character in ASCII. The only non alphabetic
>> control characters are @,[,\,],^,_
Well, strictly speaking, there are NO control-characters in ASCII.
The character codes in [20,7E] (hexadecimal - as are all the numbers
that follow) are the printable characters (note the SP character [blank] in
the first row, first column (20) and the lack of an entry in the last
row, last column (7F)):
! " # $ % & ' ( ) * + , - . / 0 1 2 3 4 5 6 7 8 9 : ; ?
@ A B C D E F G H O J K L M N O P Q R S T U V W X Y Z [ \ ] ^ _
` a b c d e f g h i j k l m n o p q r s t u v w x y z { | } ~
The character code 7F is the DEL character. The character codes in
[0,1F] are so-called "control characters". They are:
NUL SOH STX ETX EOT ENQ ACK BEL BS HT LF VT FF CR SO SI
DLE DC1 DC2 DC3 DC4 NAK SYN ETB CAN EM SUB EXC FS GS RS US
Some intrepid hackers like to generalize from the first terminal
they ever used. Others believe that people should memorize this chart
and simply remember that "the control key turns off the '60' bits."
Most of the time, these strategies work. Sometimes (often) you
run across a piece of hardware that treats the mapping from keys to
"control characters" slightly differently. My personal strategy is to
believe that there is NO STANDARD for mapping key-chords involving
Control to ANY particular character, and adapt to terminals as I find
them. [very good advice, I believe. Werner]
>> Use CMD-space to generate the null (^@ is what you wanted)
More accurately, what you want is NUL. MacTerminal sends a NUL on
^SP (lots of other terminals do that, too.)
>> Use CMD-6 to get out of Telnet (is this why you wanted CMD-~)
AHA! You wanted the character RS. MacTerminal hackers KNEW that
you'd want that to get out of Telnet, and optimized it for you (aren't
they nice?) Actually, I've always thought of RS as ^^, and have run
across terminals that produce it on ^6, but I've never run across anyone
who described it at ^~. What terminal were you using before? [it was a
Teleray, a 'losing' terminal because of it's quirks in the use of the
control-key and ESCAPE-sequences controling the display. has some nice
features, also. - Werner]
Happy hacking-
-Ken Sloan
