Download: http://archive.info-mac.org/cfg/resolute-10.hqx
Resolute V1.0
Freeware ©1998 AKUA interactive media AG.
Resolüte is a Control Strip Module (CSM) that allows configuration of
displays independent of the display connector. I personally think that
Apple should show all these options when you choose the "All
resolutions" in the Monitors & Sound control panel, but alas, they do
not. You can go buy a connector that has dip switches... But Resolute is
free.
Display Manager 2.0 is the minimum needed. It has been tested on System
7 and 8.
by Gregory Lemperle-Kerr
[email protected]
