Reorder Disk Icons
Reorder Disk Icons
Download: http://archive.info-mac.org/cfg/reorder-disk-icons.hqx
Reorder Disk Icons is a useful AppleScript Applet that changes the
order of the disk icons like it was before the Finder 8.5.
The pre OS 8.5 Finder uses the mounted disk order. The Finder 8.5 or
higher places the disk icons according to the disk's free space, with
the startup disk first.
Note: The changes are temporary, the original positions will be used
when you restart your Macintosh or if you run an installer that quits
all applications before doing installation.
To place your disk icons as previous Finder did it, just copy the
Applet into the "Startup Items" folder.
To restore the originial disk positions just restart your Mac without
Reorder Disk Icons in your "Startup Items" folder.
