Reanimator 2.0.7
Reanimator 2.0.7
Download: http://archive.info-mac.org/cfg/reanimator-207.hqx
Reanimator 2.0.7 (an update)
What is Reanimator?
Reanimator is a utility for automatically restarting all applications and
background-only processes killed by another process. It can also be used to
quit all running processes and restart them later.
System requirements
68020/030/040 or PowerPC;
64 KBytes free memory for the extension;
Mac OS 7.1 or later.
What's new in Reanimator 2.0.7?
- Fixed a long standing bug in the registration code validation
algorithm that caused the control panel to crash occasionally on 68k
machines.
- Removed any reference to FTP application in the control panel.
Installation
The Reanimator package is distributed in form of an "Installer" application.
To install Reanimator just launch the installer and follow the simple
instructions. It is recommended to restart your computer after installation.
Distribution
Reanimator is 8$ shareware.
You can distribute Reanimator freely, provided that you leave the software and
the accompanying documentation unchanged. You can include Reanimator in CD-ROMs
and other software collections only by previous agreement.
Thanks and best regards.
Federico
