RAMShush 1.0
RAMShush 1.0
Download: http://archive.info-mac.org/cfg/ram-shush-10.hqx
RAMShush is a $5 shareware control panel that overrides that annoying
alert box you get when you shutdown or restart with files on your RAM
Disk. It is especially for systems that do not allow persistent RAM Disk
contents across shutdowns and/or restarts, and should work on any system
that allows use of a RAM Disk.
Jeff Schmidt
