QuickScrap 1.2
QuickScrap 1.2
Post by Info-Mac » April 2nd, 2000, 10:00 am
Download: http://archive.info-mac.org/cfg/quick-scrap-12.hqx
QuickScrap (QS) can do things to make your life so much easier when using
your Macintosh. Have you ever wanted to be able to easily store a piece
of information from any document you're reading or editing? Here's how
it's done with and without QuickScrap:
Without QuickScrap:
- select the information
- type Command-C to copy
- switch to finder or use the apple menu
- open your other application or scrapbook
- type Command-V to paste in the info
- switch back to the first application
- continue where you left off
With QuickScrap:
- select the info
- type your QS hotkey
- continue
With QuickScrap, you can send the data on the clipboard instantly to a
scrapbook file, a ScrapIt Pro file or a QuickScrap file by pressing a key
(or keys) of your choice! The QuickScrap file can be used as a multiple
clipboard containing as many as 100 items (you choose how many items it
will hold). You can have QuickScrap automatically copy any selection
you've made in any document you're working on and send the data directly
to a scrap file with one keystroke.
Another handy feature of QuickScrap is that you can set a "Hotkey" to
allow you to type a quick note (or edit text on the clipboard) and send
it to a scrap file without having to leave the application you're
currently in.
You can set another key to open any scrap file, display all the items in
a gallery view or alphabetical list view and allow you to select an item
and instantly have it pasted into whatever document you're editing.
New features added in version 1.2:
New interface (resize & move window), bug fixes (correctly checks for
maximum scrap file size now), Special Applications list now works
properly. Now works with ScrapIt Pro v5.5. Will create name from first
characters of text when copying text to a scrap file.
