PW Disk Guard v2.5 (MOS)
Download: http://archive.info-mac.org/cfg/pw-dgv-25-mos.hqx
Requirements:
Mac OS v7.1.4 + or 8.0 +
AppleScript v1.1
BBEdit Lite (to read documents)
Size:
Full Folder: 1.8 MB
Features:
* Bulleted password.
* Easy to change password.
* Case, hyphen, space, diacritical and punctuation sensitive password.
* Choice to activate on startup.
* Works on both MacOS 7.x an 8.x.
* Easy to configure.
* Easy to register using Kagi.
* Full documentation.
* Easy to uninstall all traces of it if you decide to get rid of it.
Purpose:
PW Disk Guard has been made to give Mac users a simple but effective way to
protect their computer from people they don't want using it.
Cost:
ShareWare:
Kagi
$10.00
Tech Support:
Free.
Updates:
v2.6: More configuration features.
v3.0: More features:
* Multiple users.
* Locking disks.
