Pseud040
Pseud040
Post by Info-Mac » October 28th, 1997, 11:00 am
Download: http://archive.info-mac.org/cfg/pseud-040.hqx
This is the first public release of Pseud040, a shareware control panel
which allows 68020 and 68030 Macs to run 68040 software! Yes, that's
right, you can now run Dark Forces on a Mac II! It's shareware ($20).
I hope owners of vintage Macs get some more years out of their machines.
I guess you should put this in the Configuration section (or wherever
SoftwareFPU is, since they do similar things.)
Michael Connolly
