Process Manager 1.4.2
Post by Info-Mac » February 12th, 1999, 11:00 am
Download: http://archive.info-mac.org/cfg/process-manager-142.hqx
Process Manager is a control strip module that allows you to view and
switch with ease between your Mac's processes (running programs.) It works
with Control Strip and is Extensions Strip Savvy.
1.4.2 Displays the new 32-bit icons under OS 8.5 and lets the file dialog
be displayed in Control Strip 2.0 and Exensions Strip 1.9.1.
To download:
http://www44.pair.com/ammon/skidperfect ... .2_FAT.hqx
Skidperfect Software, Inc.
31 Jan 99 - Extensions Strip 1.9.1 released
