Prestissimo 1.0.1 - Mac OS 8.5 Utility
Download: http://archive.info-mac.org/cfg/prestissimo-101.hqx
Prestissimo is a freeware control panel for controlling all of Mac OS 8.5's
new features including:
* The new tear off application palette
* Keyboard shortcut to change applications
* Scroll bar appearance
Prestissimo has been comprehensively tested under under the final version of
8.5 which along with instant feedback and easy restoration of defaults make
it ideal to tinker with the new features without fear. Although it is
packaged as a control panel it will not cause instablities as it patches no
traps (in fact you don't need to install it for it to work).
Prestissimo 1.0.1 fixes some problems with incorrect error
reporting/handling and improves it's interaction with Mac OS 8.5.
System requirements:
* Power Macintosh running Mac OS 8.5
For more information, please read the Read Me file enclosed, or visit our
Web page:
http://www.polymorph.net
Nick Beadman
PolyMorph Software Development
