PowerPCheck 3.2J FAT (Japanese version)
Download: http://archive.info-mac.org/cfg/power-p-check-32-j.hqx
PowerPCheck 3.2J is the Japanese version of Alessandro Levi Montalcini's
original.
FAT VERSION - CONTAINS BOTH 680x0 AND NATIVE POWERPC CODE
* PowerPCheck is a cool drag & drop utility that looks for native
PowerPC code inside applications, control panels, extensions and all
other executable files. It can check individual files as well as
folders or entire disks; it inspects both the data fork and the resource
fork of each file and creates a detailed text report of all the native
code it finds. Version 3.x can also remove the PowerPC or 68K code from
the inspected files.
New in version 3.2: - Changed the report generation options to allow
customized reports for specific kinds of applications (68K, PPC and
FAT). Switched the payment method to Kagi. Recompiled with CodeWarrior
11.
This is $10 shareware. Have fun and support Alex.
The Japanese versions of Alessandro's programs are available at:
http://persoweb.francenet.fr/~alm/alm_files.html
ftp://ftp.alpcom.it/software/mac/LMontalcini/localized/
Haruka Ishi [email protected] May 8, 1997
