Port Juggler Update 4.6
Download: http://archive.info-mac.org/cfg/port-ju ... pgrade.hqx
Here is the latest software update version 4.6. Please read the "ReadMe" file
first, it contains the necessary setup and installation instructions.
There are two extensions that need to be manually dragged into your extensions
folder. Use one of the following combinations:
1. "Port Juggler" & "PJ Classic" for Port Jugglers received before June of '96.
2. "Port Juggler" & "PJ 4x" for the Port Juggler 4x.
3. "Port Juggler" & "PJ Power" for the Power Port Juggler.
P.S. If you have problems with the attached files, you can down load it directly
from the WWW via FTP at "ftp://members.aol.com/momentumts/portjuggler".
