OSL Antibody 1.0
OSL Antibody 1.0
Download: http://archive.info-mac.org/cfg/oslantibody-10.hqx
OSL Antibody will check your system (OS8 or better only) for the
presence of Object Support Library. If it finds the OSL, it will trash
it. Since OS8 rolled the functionality of OSL into the System, and many
installers also place the OSL into the extensions folder no matter what
version of system software you are running, this is a good way of
avoiding potential problems and getting rid of an unwanted file.
System requirements:
1. OS8 should be installed. If you are running any system version
lower than OS8, this script will throw out a dialog telling you that you
need to be running OS8, and then quit when you dismiss the dialog. If you
are not running OS8, you probably want to use Object Support Library,
anyway.
2. Applescript must be installed on your system. This is a standard
part of the MacOS these days, so it should be installed if you are
running any version of System 7.5 or higher.
For more information, visit my web page at
http://www.inch.com/~tjb/scripts.html
or email me at [email protected]
Tom Bovo
http://www.inch.com/~tjb/adoor.html
