software that records what you open
Harry
Post by Harry »
Hi all
Does any one know of any type of software that records the time date and file name of files that you open. I need to keep a record of which files I open and when.
Thanks in advance
Re: software that records what you open
You might be able to do something like this in Applications -> Utilities -> Console, but I'm not entirely sure.
EDIT:
Download this Finder Saved Search Query file, open it and you'll find a history of all files opened in the last 10 years. You can sort it by Last Opened time in the Finder when viewing it in list view:
Opened File History.zip
(1.14 KiB) Downloaded 442 times
