os8-deskpict-cycle-1.0
Download: http://archive.info-mac.org/cfg/os8-des ... cle-10.hqx
OS 8 Desktop Picture Cycle 1.0 - OS8 is out and it finally incorporates a desktop
picture. Yay! But it doesn't change it automatically. So I wrote a little very
simple AppleScript App that cycles through the pictures/aliases in a designated
folder every time it's run, so at least every time you start up, the picture will
have changed. 1) Make a folder on your desktop called "Desktop Pictures" 2) Add a
picture or alias of a picture and call it "Current Picture" 3) Add up to 10 more
pictures/aliases and name them "1", "2", "3" Š "10" 4) Put the DPC app in your
"Shutdown Items" folder in your System Folder. 5) Open the Desktop Picture
control panel and set your picture to the "Current Picture" file in the "Desktop
Pictures" folder.
