Hi. I've some problem with the configuration of Mail for connection to an Exchange Server.
I've downloaded a certificate and then i tried to connect.
I know the username the password an the server address. But in the configuration if I put "Exchange2007" and fill the fields, i rexeive error.
I've tried entourage with same data and work perfectly. In Mail there are very field such as Internal server, External server.
If, for example, my server address is https://server.xyz.org where i have to put thi value???
Trouble with Mail and Exchange
Re: Trouble with Mail and Exchange
Are you not seeing this screen?elimone wrote:If, for example, my server address is https://server.xyz.org where i have to put thi value???
In your example, the address server.xyz.org would be entered for the server, but depending on your specific case, it may be different. I've seen some examples online of people having to combine their server with their username.
It sounds like you may not have enough information to setup Exchange fully. Is this a possibility? Perhaps contact your Exchange server's administrator.
