Oriental Express for Asian Languages Release
Download: http://archive.info-mac.org/cfg/orienta ... s-asia.hqx
Oriental Express
Copyright © UniDoc System LLC, 1998.
Welcome to Oriental Express home page. Oriental Express is a dynamic
localization extension to enable any MacOS
compatible computer with system 7.5 or above to localize your favorite
applications into one of the Asian languages - Chinese,
Japanese, and Korean. By just a simple click, Oriental Express can turn
a English application into Chinese/Japanese/Korean
application. The localization packages for Netscape Communicator and
Internet Explorer are included.
Key Benefits
Convert your favorite English application into
Chinese/Japanese/Korean application with just a simple click.
System Requirement
MacOS and compatible personal computers with 68030 or
better.
System 7.1 or later, MacOS 7.5.3 recommended.
Minimum 8 MB RAM, 16 MB recommended.
Minimum 8 MB free storage on hard drive.
Availability
There are two distribution packages. If user already has all the
language scripts (included in CLK/JLK/KLK, localized OS or MacOS 8.5),
user
should just download the Oriental Express for Asian Languages in
download area. If user does not have the required language script,
PanALE/Oriental Express should be downloaded instead. PanALE provides
all the necessary language scripts/fonts without
Worldscript II and therefore the Chinese/Japanese/Korean
reading/browsing ability.
