The Open With Package 2.0.1
Download: http://archive.info-mac.org/cfg/open-wi ... ge-201.hqx
Open With Package lets you open documents with applications other than their
creator. You no longer have to drag those documents through multiple folders. You
don't have to launch the application and then navigate through the open dialog.
Just control-click on a document and choose from the applications on your disks
that can open it in the pop up list. You can save yourself whole seconds of
searching each time you want to open an Adobe PhotoShop file in GraphicConverter
for example (hey, this adds up). Only applications that can open all the
documents in the selection appear in the popup menu, so it doesn't take long to
find the application that you want.
The Open With Package is Shareware $10.
Version 2.0.1 fixes an installer bug, which stopped installation on
international systems. Users who have version 2.0 working need not upgrade.
This software may be distributed on commercial CDs.
Peter O'Gorman
