Open Directory Plugin for Sherlock
Download: http://archive.info-mac.org/cfg/open-di ... plugin.hqx
This is a Sherlock Plugin for Mac OS 8.5 and later that searches the Open
Directory
(http://dmoz.org/).
This directory is known for its highly relevamt search results.
I suggest that you put this file in the same directory as the other
Sherlock Plugins. This seems to be the comm directory.
This plugin is free.
It will automatically update itself if a new version is released.
Regards,
-H.P.
