Secret Folder lets you conceal a folder and its contents. It provides you
with an easy and fast way to protect documents and avoid them being seen,
modified, or erased by other users (either on a network or uninvited!). The
program is really simple to use and can be protected with a password for
extra security.
OneApp Secret Folder is shareware.
System Requirements:
Macintosh, PowerBook, Power Macintosh or iMac.
Ê
OneApp Software Site: http://www.oneappsoftware.com
