NoShift Needed 3.1
NoShift Needed 3.1
Download: http://archive.info-mac.org/cfg/no-shift-needed-31.hqx
NoShift Needed? by MyShare? Publishing Co.
REQUIRES STUFFIT EXPANDER 6 (or higher) TO UNSTUFF!
What is it?
NoShift Needed? is a clever little program written with SEVERAL people in
mind. Business people who want to SAVE time. Or say you only have one hand,
arm, toe, or other handicap (WHATEVER) to type with. It's for you. Or
maybe your just LAZY. It's for you too! It's also for you if you type a lot
of email addresses@WHEREVER. It's for you. If you have a habit of putting a
lot of things in (parentheses). It's for you. If you like to write in
shorthand & you use % 's a lot. It's for you. It's for you if your into
into + 's and _ 's it's for you also.
So what is it?? READ the NAME again!!
You can type the entire top numerical row and instead of123456789 - = you
$ % ^ & * ( ) _ + which are a lot more useful keys and when you need the
numbers 1234567890 simply use the numeric key pad on the right side of the
keyboard. Everything above has been made WITHOUT stopping to hold down the
shift key!
*TRY IT! YOUR GONNA LOVE IT. And wonder how you ever got along without it!.*
REQUIREMENTS: NoShift Needed? works with any Mac running U.S.. systems 7,
8 or 9.
*NOTE- System 7 users MUST use the ENCLOSED program called Keyboard Menu. It
allows you to have multiple keyboard layouts other than the standard U.S.
layout.
And REMEMBER! PLEASE pay your shareware fee!
