NiceStopShutDown 1.0.2
Download: http://archive.info-mac.org/cfg/nice-st ... wn-102.hqx
NiceStopShutDown v1.0.2
(c)1993-1997 Eugene Cohen
Freeware!
NiceStopShutDown will restart the computer when 'Shutdown' is chosen
from the 'Special' menu. HOWEVER, if the option key is down, the computer
will shut down gracefully (and the hard disk's head will be parked--this is
important). This extension is intended to be used on computers in lab
situations where you don't want the computers being turned off and on
continuously.
Changes since last version: 1.0.2 Updated contact information and readme file.
[please include this on the CD-ROM(s)]
