NetChronometer 1.4.6
Download: http://archive.info-mac.org/cfg/net-chronometer-146.hqx
You've probably noticed that the clock on your Macintosh drifts as
time goes by. NetChronometer will synchronize your Mac's date & time
to a highly accurate network time server.
Features include:
* You can manually synchronize the clock, or configure
NetChronometer to sync it periodically.
* Contains a large list of time servers world wide, or you can
customize it (even use an in-house NT server!).
* Stand-alone application - doesn't consume memory when it's not
running, unlike Apple's Time Synchronizer extension (introduced in
Mac OS 8.5).
* Fully Mac OS 8.5 & 9.0 compatible - it's Appearance Manager savvy!
NetChronometer requires an Internet connection using either Open
Transport or "Classic" Mac TCP/IP. It is Appearance Manager-savvy.
It will run on any 68020 or better Macintosh or Power Macintosh.
Version 1.4.6 has the following changes:
- Updated server list.
Shareware; $7 registration fee suggested. It can be downloaded from
(http://www.kezer.net/shareware.html).
