Navi iRae 1.7
Navi iRae 1.7
Download: http://archive.info-mac.org/cfg/navi-irae-17.hqx
Navi iRae is a control panel that provides menus, when you command-click
in a window's title region, that lets you navigate through the path of
the file, just like in the Finder. "Navi iRae" just looks for an opened
file with the same name as the window's one.
If it finds several opened files with the same name, it displays a menu
with every file match in submenus.
Some applications, when opening a file, copy its content in a temporary
file, and then close it (eg. Photoshop, Illustrator, Canvas,
GraphicConverter·). In version 1.1.x it made them impossible to see for
Navi iRae. But not anymore ! Now Navi iRae now looks for recently opened
files to find them. Beware ! There's not complete guarantee this is the
real file.
Beware, for best results you'll need an utility that keeps track of
recently opened files. You have several choices supported by Navi iRae :
Apple Menu Options : no special setting required
OtherMenu :no special setting required
BeHierarchic 4.0 : be sure to check the option "Apple Menu
Option Compatible"
Minimum requirements :
Mac OS 8.5 and PPC
Price : free !
New to this version (1.7)
Navi iRae is now multi-users saavy.
Added support for Corel PhotoPaint.
Corrected problems with Jade and FrameMaker.
