Multi-Resolutions 2.1
Download: http://archive.info-mac.org/cfg/multi-resolutions.hqx
Multi-Resolutions 2.1 is a control panel that enables you to use all the
resolutions your video card is capable of providing, without checking the
sense lines of your connected monitor. For instance, an Apple 15" monitor
can be set to 1024x768 etc...
Multi-Resolutions requires MacOS 7.5 or above and a Power Macintosh (PCI
or NuBus).
Multi-Resolutions is shareware ($15) and when registering with Kagi, you
will receive and unlock code that will enable Multi-Resolutions to
automatically restore your selected resolution at restart.
Daniel Tapie
IBS/Softron Media Services
