Mickey Hand 1.0.5
Mickey Hand 1.0.5
Download: http://archive.info-mac.org/cfg/mickey-105.hqx
What does ÒMickey HandÓ do? Have you noticed that in MacOS 8.5 when you hold down
the command key in the application palette or in a Finder's window when clicking,
the cursor changes in a nice hand that really reminds you of Mickey's glove ?
Mickey Hand just use that cursor in a great bunch of applications that where
designed before OS 8.5 and that used black and white hands.
Requirements
¥ Mac OS 8.5 or better
