Mindscope's Memory Profiler is a utility that shows you how much
physical, and logical RAM you have. It also displays a realtime animated
meter that shows you how much RAM you currently have left. The coolest
thing about it is its Plugin interface,
which allows you to completely alter the appearance of Memory Profiler.
You can use the standard Plugin included with the program, use someone
else's, or even make your own!
