MasterFKey1.0J - Japanese Version
Download: http://archive.info-mac.org/cfg/master-fkey-10-jp.hqx
This the Japanese version of the MasterFKey package.
Have you ever found yourself needing more than ten FKeys at your fingertips?
Have you ever forgotten which command-shift-key goes with a specific FKey?
Have you ever reinstalled your System and lost all of your FKeys?
Have you ever had the wish to see all of your FKeys in a list to select
one by mouse?
Have you ever slowed down your machine with a bunch of rarely needed
extensions?
Have you ever been afraid to spend memory for a system extension which
does only simple things which could also been done by an FKey?
All of this problems are solved by MasterFKey, the ultimate FKey utility
to manage all your FKeys as easy as possible!
