MagicalKeys 1.6
MagicalKeys 1.6
Download: http://archive.info-mac.org/cfg/magical-keys-16.hqx
MagicalKeys 1.6 - Open Finder Items by Magic keys - Freeware
With MagicalKeys, you can "magically" open up to four often-used Finder
items: volumes, folders, applications, documents, control panels, desk
accessories, etc., by quickly pressing down 2 or 3 times the modifier key
(Command, Option, Shift, Control) they are associated with. A Finder item
can be defined as: "anything that is an icon in the Finder".
Assigning a modifier key to the active Finder allows you to switch to it,
and if the Finder is not currently running, it is automatically restarted.
You can bring up MagicalKeys' control panel at any time, by having the
Caps-Lock key down while double-tapping or triple-tapping any modifier key.
Requires Mac OS System 7.0 or later (System 7.5 or newer is recommended).
Compatible with Mac OS 8.5.
"What's New since Version 1.5.3"
- The control panel is now theme-savvy when the Appearance Manager is
available.
--Michel MARIANI (a.k.a. Mikaeru)
Mikaeru Software: http://home.worldnet.fr/mmariani/mikaeru/soft.html
