MagicProgramMenu
MagicProgramMenu
Post by Info-Mac » January 15th, 1999, 11:00 am
Download: http://archive.info-mac.org/cfg/magic-p ... nu-101.hqx
Magic Program menu is a MacOS system extension that adds a "magic"
program menu to the standard Apple Menu which will contain entries to
launch all of your applications on all of your disks. This menu will
"magically" build and repair itself as you use your computer. Your
applications will be added to this menu as you use them, and they will be
removed from this menu when you delete them. Just install the Magic
Program Menu Extension into your system folder and the menu takes care of
itself.
