Mac OS Items Manager 2.0.1
Download: http://archive.info-mac.org/cfg/macos-i ... er-201.hqx
Mac OS Items Manager 2.0.1 [2000/09/01]
by Vincent Jalby, [email protected]
http://members.aol.com/vjalby/MacOSIM/
Localized versions are available from the HomePage.
Product description
Mac OS Items Manager 2 is a system utility that allows to enable/disable
Contextual Menu Items, Control Strip Modules, Apple Menu Items and Fonts.
New in this version
Mac OS Items Manager 2.0 has many new features including:
¥ Improved user interface
¥ Support for Apple Menu Items
¥ Full customization of folders managed by Mac OS Items Manager
¥ Support for Drag and Drop
¥ New icons (by Yoshi Sakuma)
¥ Norwegian version
¥ And much more!
Version 2.0.1 fixes a bug which prevents Mac OS IM to run, when one of the 4
supported folders is missing. It also fixes Danish Apple Menu folder name.
System Requirements
Mac OS Items Manager 2 runs on any PowerMacintosh with MacÊOSÊ8.0 and later,
in one of the following languages: Catalan, Chinese (Simpl. & Trad),
Croatian, Danish, Dutch, English, Finnish, French, German, Italian,
Japanese, Korean, Norwegian, Polish, Spanish, Swedish, Turkish.
It will be available in Dutch, English, French, German, Italian, Japanese
and Norwegian.
Shareware Fee
MacOS Items Manager is distributed as Shareware.
A license for a single user will cost $9
($45 for a Site License, $90 for a WorldWide License).
