NewNOTEPAD II 1.8.2J - Japanese Version
Download: http://archive.info-mac.org/app/new-not ... 182-jp.hqx
NewNOTEPAD II 1.8.2 - Japanese Version
NewNOTEPAD II is highly functional notepad software.
NewNOTEPAD II supports drag and drop, so you can enter text at random
and clean it up afterwards. You will find it so useful, it might be
a good idea to have it on the desktop, just a click away.
Features :
- Each Note can have its own title and each title will appear in list
view.
- The Note can form a group and each group will appear in list view.
- The group can have up to 32767 hierarchical levels.
- A group can store up to 32767 Notes.
- List view has the interface just like Finder's list view. It shows
the contents of the Notepad file in outline form.
You can see the contents of a Group (folder) without opening the Group
in its own window.
Changes in this version :
* Improvements
- Add Jedit version3 format to the output text format.
* Fixed Bugs
When system will be shutdown, cannot do quit NewNOTEPAD II application.
When make new note and do 'Find Next', Seek Error occurs.
In multi-monitor environment, Icon window isn't indicated to the position
that should be.
NewNOTEPAD II is distributed as shareware. You may try it for 30 days,
after which we ask that you either delete your copy or register it by
sending $20(US) or 2500 YEN.
Please check web site.
http://hisadon.cup.com/
