MacOS 8.5 Managers
MacOS 8.5 Managers
Download: http://archive.info-mac.org/cfg/macos-85-managers.hqx
MacOS 8.5 Managers is a collection of 2 small AppleScripts that will help you
work effectively with Apple's new and exciting OS, 8.5, also known as Allegro.
The first file, Scroll Manager, will help you deal with that stubid command
"Smart Scrolling". I give you the option of just using double arrows, but at bot
ends or a few other alternatives.
The other AppleScript helps you configure the Application Switcher dock to fit
your way of working. Please se the separate read me for additional information.
These AppleScripts should work on any machine that is capable of running Allegro, and that means all PowerPC-based computers.
/Bye for now, David Remahl
