Download: http://archive.info-mac.org/cfg/log-timer-j.hqx
This is the Japanese Version of the LogTimer utility.
LogTimer is a System Extension which simply writes the time for System
startup, Restart and Shut down into a logfile on the Desktop.
To use LogTimer INIT you have to drop it on top of your system folder and
it goes to the extensions folder automatically. After restart you will find
a file called 'LogTime' on your desktop. This file can be opened with
Simple Text to see the log times. The file is created automatically if it
does not already exist. Everytime you start your system, or you shut your
system down or you reboot your system an entry is added.
I wrote this little Extension for one of the registered users of CopyPaste
who had this idea. It is a quick hack, but it does not patch any trap and
costs no CPU time except at startup and shut down. Therefore it is very
unlikely to cause any problems. LogTimer is Freeware, which means it is
free of charge, free for any non commercial use, free from support and free
from any guarantee.
LogTimer is released to the public as an advertising agent for CopyPaste,
the productivity tool for your Mac, downloadable from http://www.bridge1.com.
CopyPaste gives you ten clipboards instead of just one! How many times have
you found yourself going back and forth copying in one application and
pasting in a different application, wishing to yourself that you could copy
5-10 items at a time, then go to another application and paste each of
these items. Now you can! Type the usual keyboard command for copy or cut
and then any number between 1 and 9 before releasing the command key. Paste
works in the same way. In addition to the normal clipboard you now have
nine more.
