Submission
Submission
Download: http://archive.info-mac.org/cfg/lcd-scr ... ter-10.hqx
URL: http://www.darkeagle.com/
description:
With this little Application for OS X you can test the Active Matrix Display
of your PowerBook or iBook for stuck pixels.
type: FreeWare
version: 1.0
system requirements:
OS X 10.1.x, Carbon Lib 1.5, Macintosh With a LCD Display (Active Matrix)
Binary may be included on all CD ROMs as long as the original folder is
intact.
Name of Application: LCD Screen Tester
