MultiTimer Pro 2.5
MultiTimer Pro 2.5
Download: http://archive.info-mac.org/app/multi-timer-pro-35.hqx
MultiTimer Pro is a utility for tracking the time spent on projects and jobs
performed on a Mac. MultiTimer Pro will be an invaluable asset to graphic
designers, Web designers, content creators of all types, consultants,
lawyers, accountants, and anyone who uses a Mac and either bills for their
time or needs to keep track of time for any other purpose. MultiTimer Pro is
ideally suited to self employed individuals, large companies, and everything
in between.
Here are just a few of the features of MultiTimer Pro:
* Track time EASILY, with a simple and intuitive interface.
* Track expenses as well as time.
* View a complete history of your timed sessions in a "log" window. Logs are
fully editable and can be configured in a variety of ways.
* Set hourly rates and have charges automatically calculated for each session.
* Attach notes to any or all session and expense records.
* View total times and total charges for a day, week, month, year and grand
total, all at a glance.
* Automatically start a timer when a selected file is opened.
* Automatically open multiple files or applications when a timer is started.
* Optional notification when an application quits, to remind you to turn off
a timer.
* Unique optional "floating window" is always visible, shows you the timer
status and accumulated time.
* Apply user-defined "category" labels to sessions or expenses, with attached
hourly rates or charges.
* Extensive Undo support in logs, and an option to make manual adjustments
visible as separate records.
* Unique "cross-log reports" allow you to view and sum the data from multiple
projects.
* Elegant, attractive design throughout, with Mac OS 8 platinum appearance.
* As powerful as you need, or as simple as you want; hide the features,
options and information you don't use.
The full power of MultiTimer Pro can only be hinted at here, but the
simplicity of the program is easier to describe: To start tracking time on a
new project you make a single menu selection and type in a name for the
project. Tracking the accumulated time spent on a project is accomplished by
clicking a start/stop timer button. Switch between projects with a popup
menu. View the log of a project by clicking a button. And so on -- everything
is intuitive and easy. With MultiTimer Pro you have all the features you need
in a time-tracking utility, coupled with unparalleled ease of use.
This is version 3.5 of MultiTimer Pro.
