Keyboard Lock 1.0
Keyboard Lock 1.0
Post by Info-Mac » August 4th, 1999, 9:00 am
Download: http://archive.info-mac.org/cfg/keyboard-lock-10.hqx
KeyboardLock lets you reclaim desktop space by locking
your keyboard. Once locked, you can safely place things
on it, and still use your Mac for anything that doesn't
involve typing. The keyboard is toggled simply by moving
the mouse to one corner of the screen, so it's a snap to use.
Or you can use AppleScript to password protect your keyboard.
Requires: PowerPC based Mac System 7.5 and up
Support: http://members.aol.com/halfhill
