KeySwapper 1.0
KeySwapper 1.0
Download: http://archive.info-mac.org/cfg/key-swapper-10.hqx
File name......: KeySwapper 1.0
Date of release: 10/7/99
Are you missing any keys on your new iMac, G3, G4, PowerBook or iBook keyboard such as the Forward Delete key or the End key? Wishing you had these keys? Well, now you can have those keys with KeySwapper!
KeySwapper will allow you to use any key(s) you like to emulate other keys that your computer may not have (such as the Forward Delete key, the Page Up key, the End key, etc.)! You can also disable the Caps Lock key if you wish (very useful for PowerBooks that seem to always have the Caps Lock key down when you didn¹t want it that way! :-)
This program performs functions that will benefit any Mac user and is extremely simple to set up and use. You can now define all those useless function keys on your extended keyboard (or any other keys) to perform extremely useful tasks!
System Requirements.
Min. System..: 7 on up through OS9!
Min. Hardware: Mac SE or better (Works great on PowerMacs!)
Shareware....: $5
Author.......: John V. Holder
email address: [email protected]
Home Page....: http://www.northcoast.com/~jvholder
