New version of autotasks (JAT) these have only been tested on 9.1, 3 new
features:
Lock a file from the apple menu or F1-F15 shortcut
If you got Finder pop beta scripts for it. (not approved by the autohor)
A system support control panel i.e. support
Sience this is BETA no support (use @ own risk)
Download instructions:
1. Download it
2. Un-stuff it
3. Open the file "JAT1.5 beta.img"
4. A disk will pop-up take it from there.
to get rid of just eject.
