iScreen
iScreen
Post by Info-Mac » January 15th, 1999, 11:00 am
Download: http://archive.info-mac.org/cfg/iscreen.hqx
iScreen is a startup screen replacement which replaces the old MacOS screen
with a new and exciting bondi colored startupscreen.
I recommend not only normal Mac users to download this but especially for
iMac users and the new G3 computers you should have this installed.
iScreen is only compatible with Mac OS 8 and higher, including MacOS 8.5
You can distribute iScreen freely, provided that you don't modify it
and that it is always accompanied by the other files within this folder.
iScreen is not free, it is shareware with a fee of $10.
I am 14 & own an iMac. and I always THINK DIFFERENT.
Please feel free to contact me if you have any
problems, or questions or any thing.
Muzamil Akram
