IntelliAlias 1.1.1J - Japanese Version
Download: http://archive.info-mac.org/cfg/intelli-alias-111-j.hqx
This is the Japanese version of the Intellialias package. This package
is localized to Japanese as a free service of Bridge 1 Software.
IntelliAlias is a simple solution to a simple, yet annoying problem with
aliases on the mac. When you create an alias to an application, you
can't set the size preferences of the alias. This means that to have
various size setups for a certain program, you need several copies of
the program. This is obviously not ideal. IntelliAlias solves this
problem. The IntelliAlias program is only 7k in size, so it is around
the same size on your hard disk as any other alias.
Christopher Li Bridge 1 Software English to Japanese Online Software
Localization and Management mailto:[email protected]
