Hi's universal saver 1.6
Download: http://archive.info-mac.org/cfg/his-uni ... ver-16.hqx
Hi's Universal Saver is a little application which runs quietly in the
background and automatically saves your work at an interval which you
select. It should work with any application that has a Save command (word
processors, painting, drawing, database and many, many others).
A few of its cool features:
-Warn before saving, Hi's Universal Saver can be set to warn you before
it saves. This feature gives you allows to over ride an auto save in case
you don't want to save the current changes to your document.
-Save silently, in this case Hi's Universal Saver will simply save every
time your save delay interval has been reached.
-Auto Save for all applications or you can choose to include or exclude
certain ones.
Changes since version 1.5.2:
- You now have the option to set the "Save" button as the default button
in Hi's Universal Saver's "warn before saving" dialog box. If you choose
to have "Save" button as the default, you can activate the "Save" button
in "warn before saving" dialogs by pressing the "return" key.
- Improved support for non-English systems. People using non-English
systems will be able to use the new "Advanced Options" settings to
customize Hi's Universal Saver for their language.
This new version is a free update for all registered users (Hi's
Universal Saver is shareware).
System Requirements:
Any Mac with a 68030, 64040 CPU or any PowerMac or PowerMac clone. It
requires System 7.5.3 or later. Of course, it works great with Mac OS
8.5.
For more information, please read the Read Me file enclosed, or visit my
Web site:
http://members.aol.com/wilsonware/
Thank you,
Hiram C. Wilson
