This is a utility that can hide your folders or files, so other users can no
longer see, modify or move your data. If you want to see your files or
folders again, you have to enter your password.
It is a simple and small protection for your data. (It works best
with/against young children
New in Version 2.3:
* New Easteregg
* Have Fixed some bugs
* Changed homepage adress
* Not possible any more to hide your "key" file
