Handy v1.0
Handy v1.0
Download: http://archive.info-mac.org/cfg/handy-10.hqx
Handy v1.0
by Jeff Nelson
This system extension makes the Finder replace the standard black arrow cursor
with a 3-D color hand similar to that found in the MacOS 8.5 help viewer.
Handy is freeware. By using Handy you agree that the author is not responsible
for any damage, data loss, or incompatabilities this extension may cause. If you
wish to distribute Handy via CD-ROM or other media, please contact the author via
email at [email protected]. Special thanks to Tom Maloney and Matthias Urlich.
