Gammasoft LEDDisplay
Download: http://archive.info-mac.org/cfg/gs-leddisplay.hqx
This prgram puts an LED display in the bottom left corner of your screen.
To chage what is displayed on this LED display, other programs tell it to
"open" various strings. The string contains two words. The first one is
three letters long:
First: Vertical Position: T = Top, M = Middle, B = Bottom
Second: Horizontal Position: L = Left, M = Middle, R = Right
Third: Type: D = Diagonal, V = Vertical, H = Horizontal
Decimal points are TDP or BDP
Unlike other Gammasoft programs, this file doesn't require the Gammasoft
Runtime Engine. It has it's own runtime engine built-in.
If you have the Gammasoft Runtime Engine: When you decompress this file, be
sure to put it in the same folder as the Main Menu file. Also put an alias
of the Gammasoft LEDDisplay file in the `Data folder. Make sure the alias
doesn't have an " alias" suffix or a space after it's name.
