Google Plugin for Sherlock
Download: http://archive.info-mac.org/cfg/google-src.hqx
This is an update to my Google plugin, which enables Sherlock to search
Google, a powerful Internet search engine.
Please notice that I am not affiliated with Google in any way.
This replaces the file currently in the cfg directory, which no longer
works. Please remove the old version from your archives.
This plugin will automatically update itself if a newer version becomes
available. If it doesn't work right away after downloading, an update may
be available. Please wait three days (after which the automatic update
will occur), or check out my web site below for an update.
This and other Sherlock plugins can be downloaded from
http://www.aardvark.at/software/
Regards,
-H.P.
