Gestalt.Appl 2.7.9, freeware
Post by Info-Mac » July 23rd, 1998, 9:00 am
Download: http://archive.info-mac.org/cfg/gestalt-appl-279.hqx
Gestalt.Appl is a tool that allows you to check all gestalt selectors
posted by Mac OS or by any other piece of software. It is also a
database including information about your system environment. You see
not only some technical infos but also understandable interpretation
of most codes (in English).
As Rene G. A. Ros said in his Gestalt Selectors List, Gestalt.Appl is
the 'official' gestalt hunters tool! Version 2.7.9 was compiled on
15 July 1998 and its database was updated the same day. Documentation
is enclosed. If you know about missing information in this program,
do not hesitate to share it with me! Thanks.
Jean-Pierre Curcio
