Generator - Sega Genesis/Megadrive emulator
Download: http://archive.info-mac.org/cfg/generator-003.hqx
Sega Genesis/Megadrive emulator for the Macintosh. Reasonable
compatibility and feature range, albeit it does not have sound support. It
is quite fast and should run well on 100MHz+ PowerMacs. Freeware. (PPC only).
