Info-Mac Digest V12 #76
Subject: Info-Mac Digest V12 #76
Date: 20 May 94 17:35:28 GMT
Distribution: world
Lines: 2614
Info-Mac Digest Fri, 20 May 94 Volume 12 : Issue 76
[*] 500 Cards v0.9.3
[*] Alice 2.4b2; offline xrs, qwk, bluewave reader
[*] Amtrak North East Corridor schedules
[*] Animorpher 1.0
[*] Castles:S&C Crowning Guide
[*] ChunkJoiner 1.1; Join a group of files into one
[*] credits-display-101-updt.hqx; hc credit dialog updater
[*] csmp-digest-v3-027
[*] csmp-digest-v3-028
[*] Delete MerryXmas; HyperCard Merry Xmass info and killer
[*] demo - StoneTable; List manager dropin replacement
[*] dialog-display-20.hqx; hc windowing software
[*] Disk Charmer 1.4.7; Prevents writing w/out password
[*] DiskLocker 1.0v1; Write lock a disk with password
[*] DiskLocker; Write lock disks with password
[*] FaberFinder 4.1.2
[*] fracppc10b1.hqx; Mandelbrot Set Generator for PPC
[*] FrontDoor v1.1.7; Network access control
[*] GTQ Scripting Lib; 65 AppleScript extensions
[*] Halma 1.0 (source code); Solitare like game
[*] Halma 1.0; (solitare like board game)
[*] Hellcats/Leyte FAQ, Version 2.5
[*] Hex Keyboard
[*] HyperGrapher v1.0'
[*] LifeMaker 2.1 Cellular Automata Program
[*] MacHTTP 1.3
[*] Macintosh Models List (mac/misc/documentation/macfactstwo940516.txt)
[*] Macintosh screensaver Frequently Asked Questions (FAQ) v2.1
[*] Midi Typer 1.0
[*] More Electronic Greeting Cards
[*] Morph 2.01 PPC updater
[*] nancys-textures-grp-5.hqx
[*] Notebook Maker; Convert text into stand alone application
[*] PowerBook Insomnia v.3.2; Helps 'memory-effect' on batteries
[*] Right On Time 2.6
[*] ScriptRunner1.04; Run scripts
[*] SetupPartitions 1.0.3; Hard partition Apple SC disks
[*] Slot Machine v1.0; a HyperCard based game
[*] Solution for 'The Journeyman Project'
[*] Sounds Helper 11v1; Play sounds in background, rec long sounds
[*] speedometer-powerbook520sit.hqx; Blackbird performance
[*] Speedometer 4.0.sea (Fat Binary)
[*] Spheres!; place pipes, balls in the holes game
[*] Strange Ways #9 for mac
[*] Symbionts 2.4.1; Detailed info on loaded extensions
[*] Symbionts 2.4.1; Update -- info on loaded extensiosn
[*] Telnet2.6.1d1 Source Code
[*] Tiggr's Clock 1.0
[*] Timekeeper 3.1 demo; track time spent on projects
[*] UnderWare 1.0->1.0.1 updater
[*] UUParser 1.72
[*] Word StdFile Color Icon Patch; Add color icons to file dialog
[*] xupdater-101v2.hqx; Update software Perspectives xcmd/xcmds
(Q) Disk capacity limits - 80MB just ain't enough!
[FWD] [D[D[DApparent Bug in System Update 3.0
Accellerators + Frame Buffers for SE
An alternative to MountImage1.2b2
Application monitor?
Book available for MPW? (A)
Calendar
CD-Rom Setup
DataScan equivalent [A]
Email for Daynafile makers (q)
File Server Shut Down ???
GL viewer for the mac
Info-Mac Digest V12 #75
InterSLIP
Invisible name
Laserwriter NT Repair
Mosaic (Q)
NEC SW 2 90 toner cartridges
Networking Problems
NisusWriter 4.0
PB100 Battery lifetime?
Power User CD-ROM
Printer Selection without Chooser (R)
problems with System update 3.0 (C)
Problem with ZTerm
Quadra 605 on an inverter (A)
Re-MountImage1.2b2.warning
Record Button
Soft-PC and MS-DOS Kermit
SuperATM Conflicts with Network Connection? Help!
SURGE ARREST
Unable to access mailto: links using NCSA Mosaic
Wanted: Drag & Drop text encryption (A)
Why is DayStar PPC card so expensive? (R)
Yamaha Speaker Problems (Q)
The Info-Mac newsgroup is moderated by Bill Lipa, Gordon Watts and Liam Breck.
[36.44.0.6]. Help files and indices are in /info-mac/help.
Mail articles for inclusion in the digest to [email protected].
Send binaries to be placed in the archives to [email protected].
Date: Mon, 16 May 1994 14:41:36 +1300
Subject: [*] 500 Cards v0.9.3
500_Cards version 0.9.3 - This release replaces all previous versions.
500_Cards pits you and your computer partner against an all computer
partnership in that favourite ol' card game; 500 - first team to 500 wins
(or first to -500 looses!). I'll avoid making any grand promises about the
computer players abilities - they're okay but can/will be improved. The
card-table window fits snuggly on a 9" monitor though more recent macs get
the advantage of colour!
New in this release:
* Added a LEVEL menu which allows you to select how 'confident' the computer
players are. There are four levels: Safe, Brave, Reckless & Frenzied. The
default is Safe and previous versions played just to the brave side of
safe.
* Computer player bidding is (re)balanced to get them away from going no trumps
all-the-time. (I think I've finally got the balance about right, comments?)
* Reworked the main event loop to speed up the computer players. Much Better.
* Fixed a couple of graphics and GUI consistency problems.
* Edited the ReadMe! file using SimpleText - if you don't have it then get the
new Hardware System Update (version 3) from Apple. (NOT me!)
The good news - I've tested this game on a Classic, a Colour Classic and a
LC475 (all running Syst7) and the thing works just fine. Macs running
System 6 (but with _WaitNextEvent) should also be fine.
The better news - I've fixed the problem with PowerMacs (heck - it looked like
8bit colour to me but 16bit+ colour offworlds need more memory than the game
has). 500 runs fine on at least a 6100, though you could mistakenly think
the computer players are playing Snap! given how fast they throw down their
cards!!! (Hmm, I might have to slow the game down for the PowerMacs...)
Denis A. Birnie
[Archived as /info-mac/game/crd/500-cards-093.hqx; 41K]
Date: Tue, 17 May 1994 11:06:49 -0500
Subject: [*] Alice 2.4b2; offline xrs, qwk, bluewave reader
This archive contains the latest incarnation of Alice, an offline .XRS,
.QWK, or BlueWave reader. Alice may also be combined with a FidoNet mailer
program (Charon/Formula One) to form a complete Macintosh FidoNet "Point"
setup. Alice is not yet fully compatible with the Power Macs. Please go
over the "Read Me" files for additional changes as well as information on
configuring the new BlueWave option.
Shareware $15
Author: Michael Keller of "Mine Design"
[Archived as /info-mac/comm/alice-24b2.hqx; 800K]
Date: 17 May 94 11:10:00 EDT
Subject: [*] Amtrak North East Corridor schedules
These are two text-format files containing the complete May 1994
schedules for Amtrak's Northeast Corridor trains. You can open
them with a spreadsheet or database program to get the schedule
for trains in your area.
Data entered by Dennis Rockwell and edited by Matthew Mitchell
The authors assume no responsibility for errors and omissions, but
we have tried to check it carefully. Amtrak schedules are subject
to change without notice. Call 1-800-USA-RAIL for current information.
A project of the members of The Railroad List, rec.railroad, and the
Delaware Valley Association of Railroad Passengers, PO Box 7505,
Philadelphia, PA 19101.
A complete set of Amtrak timetables in 75-column text format,
suitable for including on Gopher systems, will be released very soon.
Contact for information.
Compressed with Compactor: may be freely distributed as long as
they remain in complete form with the README file attached.
Permission to include in Info-Mac CD-ROM granted, but these files
are expected to be outdated in November 1994.
[Archived as /info-mac/info/nms/amtrak-nec-schedule.hqx; 15K]
Date: Wed, 18 May 1994 10:34:41 -0400
Subject: [*] Animorpher 1.0
[I am not the author of this, but am passing it on to Internet sites with
author's permission. This file is _only_ useful to users of Ray Dream
Designer 3.x. - John]
Animorpher (C) 1994 by Michael Frazier. Shareware $25.
Snipped from ReadMe file:
>Animorpher (C) will allow you to do animation and three dimensional morphing
>with Ray Dream Designer (C) 3.0.x. It takes two keyframes you create in
>Designer and calculates the between frames. You then render the frames
>using the Designer batch queue. Animorpher (C) is not a plug-in. It is a
>separate application that operates on Designer documents.
Enjoy!
[Note to moderators: please post in Macintosh graphics or 3d graphics
utilities area.]
[Archived as /info-mac/grf/util/animorpher-10.hqx; 165K]
Date: Tue, 17 May 1994 11:42:22 -0500 (CDT)
Subject: [*] Castles:S&C Crowning Guide
A Crowning Guide to Castles: Siege & Conquest
Version 1.0 May 1994
Please direct all comments and additional tactics and strategies to
"[email protected]".
This guide is written presuming players are playing the "Impossible" level with
"Geographic" product distribution. Hence if one comprehends the winning
approaches elucidated in this guide, one should have less trouble applying them
in the lesser playing levels. Another assumption is that players are
role-playing the Valois ruler.
Introduction
CS&C is an excellent strategy game that has tremendous play and replay values
through the many carefully and splendidly accomplished implementation of game
elements. Computer City sells it for $39.95 versus $49.94 in Software Etc in
Houston.
This player has played as the Valois King, Yoyoboy, to be declared King of
Bretagne by The Pope in the month of January, in the year 1819 after the death
and resurrection of Our Lord Jesus Christ, with the rating Emperor (points
above 12000) in the Impossible level. The following is an excursion of the fine
points King Yoyoboy has gleaned through those tumultuous years of intense
administrative, diplomatic and military maneuvering.
General recommendations:
0. 1 to 4 combined Infantry and archer will cost 1 gold and 1 food to maintain.
5 - 9: 2 of each. 1 to 4 knights will cost 2 gold and 2 food to maintain. 5 -
9: each. IMHO, this is the result of the "round-up" algorithm used and a glitch
since 5 I/A units should still cost 1 instead of 2 gold/food.
1. Save game often.
2. Use "Save as..." to create saved games of different names every year or two.
This allows one to restart from games dated not long but long enough ago in
cases of terrible decisions or strategies that have doomed one's current game.
[Archived as /info-mac/game/com/siege-and-conquest-guide.txt; 11K]
Date: Wed, 18 May 1994 16:03:54 +0100
Subject: [*] ChunkJoiner 1.1; Join a group of files into one
ChunkJoiner is a small utility that lets you join (concatenate)
any group of files in a single piece.
Select the files you want to join, and drag&drop them onto ChunkJoiner.
ChunkJoiner works on any Macintosh, but it
**requires** System 7 or later.
Life is easier with a drag&drop interface.
New in 1.1:
Various fixes;
new handy option if your e-mail gateway splits long messages;
now saves its preferences.
Enjoy yourself and remember the $5 shareware fee!
Fabrizio Oddone
Leaving Real Soon Now for a poorly timed vacation;
do not expect answers to bug reports, fan e-mail, etc.
until June 7th, 1994.
[Archived as /info-mac/disk/chunk-joiner-11.hqx; 34K]
Date: Wed, 18 May 94 11:11:38 EDT
Subject: [*] credits-display-101-updt.hqx; hc credit dialog updater
Software Perspectives - CreditsDisplay 1.0.1 Update
CreditsDisplay is an XFCN for HyperCard which enables developers
of stackware to place colorful credits dialogs into their
software. Version 1.0.1 fixes a small bug relating to PICT
resources and resource ID numbers.
This update module requires XUpdater 1.0.1v2 or greater in
order to update your existing CreditsDisplay 1.0 stack.
XUpdater 1.0.1v2 is available from most online services and
the Internet.
[Archived as /info-mac/card/credits-display-101-updt.hqx; 6K]
Date: Sun, 15 May 94 21:57:08 MET DST
Subject: [*] csmp-digest-v3-027
C.S.M.P. Digest Sun, 15 May 94 Volume 3 : Issue 27
Determining if user has a CD ROM drive
Lex and Yacc for Mac Programmers
PowerMac FP performance - interesting results????
Saving the floating Point Registers
The NewWindow case
Truetype font format specification: No longer available from Apple ?!
[Archived as /info-mac/per/csmp/csmp-v3-027.txt; 79K]
Date: Wed, 18 May 94 14:13:10 MET DST
Subject: [*] csmp-digest-v3-028
C.S.M.P. Digest Wed, 18 May 94 Volume 3 : Issue 28
CRC-16 routine in C for native code
CodeWarrior Gold Education Price
How to write a bullet-proof lib?
PixMap to mask
Posting an event to another application?
Shared memory...
Unmounting all volumes?
[Archived as /info-mac/per/csmp/csmp-v3-028.txt; 60K]
Date: Wed, 18 May 1994 21:40:28 +1000 (EST)
Subject: [*] Delete MerryXmas; HyperCard Merry Xmass info and killer
About This Document
This document contains information on
* the Delete MerryXmas stack
* the MerryXmas virus
* how to use Delete MerryXmas
* freeware legal information
* contacting the author
What is Delete MerryXmas?
Delete MerryXmas 1.0 is a HyperCard stack that will check your
stacks for the MerryXmas HyperCard virus. It can also install
protection into your Home stack to detect and remove the
MerryXmas virus automatically. Most (if not all) virus
protection programs cannot detect this virus.
What is the MerryXmas Virus?
The MerryXmas virus infects stack scripts, starting with the
Home stack, and any other stacks that you open thereafter. The
virus infects HyperCard (and possibly SuperCard) stacks
*only*. It does not infect any other files on your hard disk.
How to Use Delete MerryXmas
Delete MerryXmas 1.0.2 requires HyperCard version 2.1 or later,
and at least as much free disk space as the size of the
largest stack to be checked.
1. Double-click the Delete MerryXmas stack to open it.
The stack immediately disinfects your Home stack, to
avoid errors from an existing MerryXmas virus infection.
2. Click the Add... button.
To add whole folders or hard disk volumes, hold down
the Option key as you click the Add... button.
Repeat step 2 to add stacks from more than one location.
3. Select the stacks you want to optimize.
4. Click Start.
A grey bar shows the stack's progress through the list
of stacks. When all stacks have been checked, a report
appears.
5. Click Save.
A dialog box appears for you to name the report. Click
the Save button (or press the Return key).
6. Click Done.
To stop the optimization at any time, click the Stop button.
After confirming your action, Delete MerryXmas will stop
checking stacks in the list, leaving the remaining stacks
untouched. (At certain times, the Stop button is dimmed and
the current process cannot be canceled.)
Scripter's Note
If you enjoy scripting in HyperCard as much as I do, you're
probably quite likely to end up wanting to take it apart.
A word of warning: Delete MerryXmas has been designed to work
best in its original, *locked* state, so please tinker with an
unlocked *copy* only. Also, unlocking Delete MerryXmas may
result in its being infected, so please keep it locked.
Legal Notice
Naturally, I am not responsible in any way for any losses or
damages resulting from your possession or use of this
software. Please use this software exclusively at your own
risk, and if in doubt, only use it on a backup copy of any
stack.
This software is Freeware, but is not in the public domain.
It remains the property of, and is Copyright (c) 1994 by
Simon Poisson. All Rights Reserved. XFCNs: FullSFPack,
GetDir, GetFInfo, GetVInfo, and FullSFPack (c) Frederic Rinaldi.
Simon Poisson
FirstClass E-Mail:
Simon Poisson,MacInTouch
Snail Mail:
PO Box 256
Darlinghurst NSW
Australia 2010
Thank you for reading this document.
Wednesday, 18 May 1994
[Archived as /info-mac/card/merry-xmas-info.hqx; 55K]
Date: Tue, 17 May 94 19:49 PDT
Subject: [*] demo - StoneTable; List manager dropin replacement
Contains an application which demonstrates the functionality of
StoneTable. Also contains a feature list and ordering information.
StoneTable is a replacement library for the List Manager and is
available for use with Think C, Think Pascal, MPW C, MPW Pascal,
and CodeWarrior C. Conversion from the List Manager is straight
forward because StoneTable contains functions with similar names
and parameters that are semantically equivalent. Often conversion
is as simple as changing the prefix of a function name from L to
TMX_ (e.g. LNew becomes TMX_New). StoneTable is royality free for
applications.
Functionality includes (partial list):
- variable width columns/height rows
- mouse down handling provides an optional interface for moving,
copying, selecting, resize a column or row plus scrolling and
editing text in a cell/title
- columns and rows can have titles
- the formatting (font, size, style, first line visible) and
for/background color of cells can vary from cell to cell and
for the title area as a whole
- application defined LDEF like drawing module
- sort columns or rows. The key type may be text, case insensitive
text, numeric text, date text, or time text.
- user written cell validation functions
[Archived as /info-mac/dev/stone-table-demo.hqx; 84K]
Date: Wed, 18 May 94 11:11:45 EDT
Subject: [*] dialog-display-20.hqx; hc windowing software
Subj: DialogDisplay XFCN 2.0
Software Perspectives - DialogDisplay XFCN 2.0
Software Perspectives is pleased to release a major upgrade to
DialogDisplay.
DialogDisplay is a great way to integrate dialog windows in your
HyperCard stacks. Version 2.0 adds a number of enhancements,
including: our new Command Processor technology for easy control,
text font, text size and text style support, plus much more.
With DialogDisplay you can have up to three custom buttons and
four custom text strings. DialogDisplay will also respond to
mouse clicks in a PICT dialog item, in case you want a buttonless
dialog.
Use in public domain, shareware and commercial software requires
a license. Please see the Licensing Information for details.
[Archived as /info-mac/card/dialog-display-20.hqx; 114K]
Date: Wed, 18 May 1994 15:54:33 +0100
Subject: [*] Disk Charmer 1.4.7; Prevents writing w/out password
Disk Charmer 1.4.7 lets you initialize (or verify) floppy disks.
It *requires* System 4.3, and runs comfortably under System 6.x.
It is able to create larger disks: you gain 8.5K on a 800K disk,
18.5K on a HD disk (if you keep one large file filling the disk,
such as a Compact Pro or StuffIt segment).
It has a "proprietary" bad sector lock out algorithm.
Enjoy yourself and remember the $10 shareware fee!
(To the moderators: do not remove this version from the archives,
because the newer versions - 2.x - no more work under System 6)
Fabrizio Oddone
[Archived as /info-mac/disk/disk-charmer-147.hqx; 23K]
Date: Wed, 18 May 1994 18:44:10 -0400
Subject: [*] DiskLocker 1.0v1; Write lock a disk with password
You must have just received DiskLocker 1.0.
But there was a little bug.
So, here is the version 1.0v1.
olivier lebra [email protected]
DiskLocker 1.0v1
by olivier lebra
e-mail :
- until June 1994 : [email protected]
- From Sept. 1994 : [email protected]
(I will spend a year in Canada !!!)
DiskLocker allows you to lock a disk (hard or floopy). When a disk is
locked, it is impossible to write to it, but you can ever read from it. You
can lock or unlock disks only if you enter the correct password (you choose
it the first time you use DiskLocker).
[Archived as /info-mac/disk/disk-locker-10v1.hqx; 92K]
Date: Wed, 18 May 1994 12:51:44 +0200
Subject: [*] DiskLocker; Write lock disks with password
Hello,
Could you put "DiskLocker" onto your archive ?
This program allows to lock and unlock disks with a password.
Many thanks.
DiskLocker=81 1.0
by olivier lebra
e-mail :
locked, it is impossible to write to it, but you can ever read from it. Y=
ou
can lock or unlock disks only if you enter the correct password (you choo=
se
[Archived as /info-mac/disk/disk-locker.hqx; 92K]
Date: Wed, 18 May 1994 16:02:45 +0100
Subject: [*] FaberFinder 4.1.2
FaberFinder is Yet Another MiniFinder.
Has "a lot" of features, though it is only 3K (the power of
good old assembler). Read the enclosed note for details.
FaberFinder 4.1 and later should **not** need the 128k ROMs
(Mac Plus or later Macs).
It works (at least) on my old, faithful Mac Plus under System 1.1,
2.0, 4.0, 4.3, 6.0.2, 6.0.8; you can use it under System 7.0
or later, but System 7 is not fully supported: you cannot
launch desk accessories from the directory dialog box, for
instance.
FaberFinder may be useful for emergency disks, where space is
at a premium.
Read the enclosed note to learn more.
Fabrizio Oddone
[Archived as /info-mac/gui/faber-finder-412.hqx; 13K]
Date: Tue, 17 May 1994 22:02:53 -0700 (PDT)
Subject: [*] fracppc10b1.hqx; Mandelbrot Set Generator for PPC
This is the first beta version (1.0b1) of FracPPC, an
application I am writing to generate fractals on Power Macs.
Currently it is little more than a toy program: it won't allow
fractal pictures to be copied to the clipboard or saved to PICT
files, for instance. The major restriction presently is: it
doesn't allow the color palette to be edited. But it is a good
example of the speed with which fractals (in the case the
Mandelbrot set) can be generated on the PowerPC.
This version can ONLY run on Power Macs -- it will not run on
68K based Macs.
- Dennis De Mars
[Archived as /info-mac/app/frac-ppc-10b1.hqx; 198K]
Date: Tue, 17 May 1994 12:37:49 --100
Subject: [*] FrontDoor v1.1.7; Network access control
This is an update for the file /info-mac/gui/FrontDoorv1.1.6.sit.hqx
In my opinion it's more appropriate, if it's placed in the
/info-mac/comm/net folder.
Brian
FrontDoor v1.1.7 (C) 1994 by Brian K. Jacobsen
Features:
* Asks the user for username/password, and mount the volumes, which
the user have access to, from up to 16 preselected servers.
- which can be placed in different zones !!!!! -
* ChangePassword on all servers which supports this
* Password protected preferencepart
* Optional: Paste ownername into username
* Optional: Allow guestaccess
* Optional: Change name of booting harddisk
- the Optional's are set on/off in the preference-part
Shareware:
1 Licens: US$25 - Site Licens: US$100
System requirements:
* System 7
* A network with access to one or more AppleShare servers
(Supports AFPVersion 1.1, 2.0 & 2.1)
* If using zones, then Phase 2
Changes since v1.1.6:
* Changed the doc-files (I was a bit to hasty to send out v1.1.6
- I included the wrong doc-files)
* Added ExitDoor
* Changed some errormessages, so they are a bit more informative
* New registration form (there were some errors in the old one...)
Doc in Microsoft Word v5.1 & ASCII
[Archived as /info-mac/comm/net/front-door-117.hqx; 55K]
Date: Wed, 18 May 1994 03:36:00 -0500
Subject: [*] GTQ Scripting Lib; 65 AppleScript extensions
UMich archives:
Please post the attached version 1.2 of the GTQ Scripting Library. The
library contains 65 scripting extensions for Apple's AppleScript automation
software.
Thanks!
Greg Quinn
Greg Quinn
Internet:[email protected] (subject to change soon.)
[Archived as /info-mac/dev/gtq-scripting-lib-12-as.hqx; 249K]
Date: Tue, 17 May 1994 14:06:36 -0400 (EDT)
Subject: [*] Halma 1.0 (source code); Solitare like game
Halma is a solitare board game in which you must move nine tiles from one
corner of the board to the other in the minimum number of moves. 21 unique
boards in all. This archive contains the complete THINK C 7 project and
resource files. Application also available; check ftp sites or e-mail
[email protected]. Finger [email protected] for complete program list.
Copyright (C) 1993-4, Mark Pilgrim. Please read enclosed file "GNU General
Public License" for licensing details.
[Archived as /info-mac/dev/src/hamla-10-c.hqx; 214K]
Date: Tue, 17 May 1994 14:05:46 -0400 (EDT)
Subject: [*] Halma 1.0; (solitare like board game)
boards in all. C source code also available; check ftp sites or e-mail
Copyright (C) 1994, Mark Pilgrim. Please read enclosed file "GNU General
Public License" for licensing details. 640K memory, 96K disk, B/W or color
monitors, system 4.1 or later. Sounds require system 6.0.7 or later.
[Archived as /info-mac/game/halma-10.hqx; 93K]
Date: Wed, 18 May 94 09:42:15 -0700
Subject: [*] Hellcats/Leyte FAQ, Version 2.5
Here's a new edition of the Hellcats/Leyte Gulf FAQ. This version
adds a pointer to the updaters to fix the sound problems on AV and
newer Macs.
It should replace the old one in game/com/hellcats-faq.txt.
Hellcats Over the Pacific FAQ/Tips
FTP from: /info-mac/game/com/hellcats-faq.txt
Posted to comp.sys.mac.games and the Info-Mac Digest
Jack Repenning
Version 2.5 UPDATE May 18, 1994 by Jack Repenning
(Patches for broken sound on certain Macs)
[Archived as /info-mac/game/com/hellcats-faq.txt; 74K]
Date: Sat, 14 May 94 19:32:43 WET
Subject: [*] Hex Keyboard
I was editing a document recently and had to insert a large number
of characters which weren't part of the Apple standard repertoire.
I had code tables printed out and realized in a flash the solution
to my problem: entry via hex address.
The Hex Keyboard is based on the standard US System 7 keyboard,
but new option-keys have been added. It's simple to use: type
and press and the character at 4E will appear;
and yields F7; and so on. The keyboard works with
Caps Lock on or off. To install it, drag it into your System Folder.
If you think this is a godsend (as I did), I'd be glad to accept
a shareware fee of $5.
Michael Everson
15 Port Chaeimhghein I/ochtarach
Baile A/tha Cliath 2
E/ire * Ireland
[Archived as /info-mac/gui/hex-kchr.hqx; 24K]
Date: Mon, 16 May 94 13:46:35 MDT
Subject: [*] HyperGrapher v1.0'
Dear Sirs:
I was going through my hard disk and found this nifty little HyperCard
graphic
calculator. It graphs equations solved for x or y, supports zooming in and
out,
etc. I thought you might like to add it to the archives, or at least check it
out. The BinHexed file is enclosed.
-=Bryan Scott=-
IRC: SirBryan
[Archived as /info-mac/app/hyper-grapher-10-hc.hqx; 35K]
Date: Sat, 14 May 1994 21:22:30 -0700
Subject: [*] LifeMaker 2.1 Cellular Automata Program
LifeMaker 2.1 is a cellular automata program for color Macs. Cellular
automata (CA) can be thought of as mini-universes. The universe starts at
some initial state and evolves according to a simple local rule. ConwayUs
Game of Life is by far the best known CA. LifeMaker includes ConwayUs Life
along with 32 other rules. Unlike most Life programs LifeMaker uses color,
allows you to change the size of the RuniverseS, and lets you create your
own rules. LifeMaker requires 32 Bit QuickDraw when used with System 6.
2.1 Changes:
1) Fixed a silly bug that caused crashes on some machines when LifeMaker
started up.
2) Fixed a bug that caused Undo Eraser to crash occasionally.
3) Flushes the data cache after compiling a rule so LifeMaker works reliably
on '040 machines.
4) Added support for recording the CA as a QuickTime movie.
5) Added balloon help to all of the menus and most of the dialogs.
6) Added HighLife rule.
-- Jesse [email protected]
[Archived as /info-mac/sci/life-maker-21.hqx; 222K]
Date: Sat, 14 May 1994 12:13:30 -0500
Subject: [*] MacHTTP 1.3
Attached is version 1.3 of MacHTTP, the WWW server for Macs. This version
of MacHTTP contains some substantial enhancements over previous versions.
New features include:
AppleScript and AppleEvent support
- MacHTTP now ships with the runtime portions of AppleScript, making
scripting available to all users. The AppleScript extensions distributed
with MacHTTP are for use with MacHTTP and cannot be copied to or used on
other machines without MacHTTP.
- MacHTTP is now fully scriptable and recordable. Use AppleScript to view
MacHTTP's dictionary for more details.
- Several new AppleEvents have been added to allow MacHTTP to be monitored
and configured from a remote workstation.
User Interface Enhancements
- Text can be copied from the status window using normal copy and paste
functions.
- MacHTTP now logs information on file sizes and displays a running total
of bytes transmitted since the server was launched.
New Functions
- MacHTTP now supports "multi-threaded" transfers for TEXT and BINARY
files. This means that MacHTTP now transfers multiple files simultaneously
to more than one client.
- PIG_DELAY and DUMP_BUF_SIZE commands have been added to the config file
to allow users to fine tune MacHTTP's behavior for use over slow networks
connections or on busy Macs.
- A VERSION command was added to MacHTTP for use in the config file. This
ensures that MacHTTP's config file matches the version of the software
being run.
Bug Fixes
- Spurious transmission of CR/LF at the end of some binary files has been
removed. This should correct problems with sending some types of files to
Windows and Mac clients.
- MacHTTP can now correctly launch aliases to applications.
[Archived as /info-mac/comm/net/mac-http-13.hqx; 934K]
Date: Mon, 16 May 1994 16:17:23 -0400 (EDT)
Subject: [*] Macintosh Models List
Subject : Macintosh Models List (mac/misc/documentation/macfactstwo940516.txt)
mac.archive.umich.edu and other archive sites:
This is an update to /mac/misc/documentation/macfactstwo94mmdd.txt
Please replace the following in your archive with this file.
Dear Readers:
Here is an update to the Macintosh Models List (AKA Mac Facts II).
About this file:
This is the Macintosh Models List (AKA Mac Facts II). It is a list
of all the Apple Macintosh models, past, present, and future. The list
provides as much information on each model that can fit on two lines.
The attached Model List III has old Speedometer 3.11 speed ratings.
I am looking for someone to update and maintain ML III. I may just drop the
speed ratings soon (ML III).
Requested information:
1. I would like to find out whether the internal speaker plays mixed, left,
or right mono for all the models. Look in the second table, Internal ports,
Speaker. If the entry for your machine is -, I need the information.
If you want to help, please let me know if the internal speaker plays mixed,
left, or right mono. I may consider making a stereo test sound available
someday.
2. I need more information on SCSI speeds for the newer models. Look in the
second table, Internal ports, SCSI. If you have this information, please
email me.
3. What is the overall speed of the new macintoshes? Classic = 1.0.
Two column format:
There are now two tables per model so that each model has two lines of
information. Note that I still stick to the 80 column wide format for easy
viewing on terminal screens. You may choose to print it out on Unix using
enscript -2rl or format it in a word processor as two columns so that the
lines match up.
Please email any corrections or additions to [email protected].
Sterling
[Archived as /info-mac/info/hdwr/mac-facts-ii-94-05-15.txt; 58K]
Date: Sun, 15 May 94 4:14:40 BST
Subject: [*] Macintosh screensaver Frequently Asked Questions (FAQ) v2.1
Here is the May 1994 update to my Mac screensaver FAQ.
If you have any interest at all in screensavers, you will want to read this
to find out what's happening in the funky wonderful world of Mac screensavers.
A number of major changes since 2.0, which was back in February. A lot has
happened, and been documented, since then. Worth a look, IMHO.
[Archived as /info-mac/gui/ad/screensaver-faq-21.txt; 140K]
Date: Sat, 14 May 1994 22:14:21 +0100 (MESZ)
Subject: [*] Midi Typer 1.0
Dear Mac Archivers,
Hope the following will be of use to all those people who can't open
the Midi Files they've downloaded. You'll probably want to put
this in Utilities, but you might put a link to it in the Sound
directory.
Midi Typer is a drag-and-drop utility requiring System 7.0 or greater. It
convinces your system that all those MIDI files you downloaded (or
bought) really are MIDI files. It is smart enough to automatically
distinguish between real MIDI files and Text files (such as "Read Me"
documentation), so you can just drop the icon of a folder or disk on
Midi Typer, and it will do the rest. You can also use Midi Typer to
change the application that will open your Midi Files.
[Archived as /info-mac/snd/util/midi-typer.hqx; 49K]
Date: Tue, 17 May 1994 20:47:48 -0800
Subject: [*] More Electronic Greeting Cards
Hi Y'all,
Here are three more electronic greeting cards from Charles Marlowe. He
says that one of these is for graduation, so right NOW! is the time to use
it, I guess.
I am not the author. Charles Marlowe's address should be in the
documentation and under the apple.
Enjoy!
[Archived as /info-mac/app/electronic-greeting-cards.hqx; 417K]
Date: Fri, 13 May 1994 20:08:17 -0800
Subject: [*] Morph 2.01 PPC updater
New Features
- PowerPC support
Morph now contains native morphing code for machines equiped with a PowerPC
chip. Performance is approximately 2-4 times faster than on a Quadra 605
(25MHz LC040).
- Faster morphing
The morphing routine has been optimized to increase performance on all
machines. Morphing is 50-100% faster than version 2.0.
Bug Fixes
- When creating a document from scratch, if the morph image window cannot
be made the dimensions of the first image loaded (due to insufficient
memory) the image will be 80x80 pixels (instead of 1x1 in 2.0).
- Memory management has been improved to handle larger images better as
well as low memory situations.
- The Tool Palette is now correctly displayed during low memory conditions
or when a Hewlett Packard DeskWriter printer driver is chosen.
[Archived as /info-mac/grf/util/morph-200-201-updt.hqx; 276K]
Date: Mon, 16 May 1994 14:14:21 -0700 (PDT)
Subject: [*] nancys-textures-grp-5.hqx
Nancy's ppats 5. This file contains a Read Me file and a ResEdit file
with two dozen ppats for your desktop. They are 256 colors, 64x64
pixels. They look good with 256 greys; 16 or 4 colors/greys isn't all
that great, but they'll work. Install them with ResEdit, Desktop
Textures, BeforeDark, Wallpaper, or ClickChange. Those are the ones I
know of. Compact Pro archive.
The response for groups 1-4 have been very positive! If you want to
know what my ppats are like, but have been intimidated by the size of
the 1-4 archive (~270k?), try this smaller group 5 archive (~70k).
Enjoy!
It may be included on info-mac's CD-ROM archive.
Enjoy!
Nancy Schneider [email protected]
[Archived as /info-mac/gui/grf/nancys-textures-grp5.hqx; 67K]
Date: Tue, 17 May 1994 12:09:14 +1100
Subject: [*] Notebook Maker; Convert text into stand alone application
Hi,
Please find attached NoteBook Maker. The standard blurb follows:
Notebook Maker
This application will allow you to take a standard Macintosh TEXT file of
data, and create a stand-alone 'Notebook' application which includes that
information in an easy to browse and search format. Notebook applications
are designed so that you can easily distribute list based information to
other Macintosh users. The low memory requirements mean that it is
especially useful in lab situations where you can have lists of do's and
dont's, helpful hints and so on.
Once the Notebook application has been created, you can use Notebook Maker
to add and delete topic entries, or remove and attach graphics to
individual topics.
Notebook Maker can also create 'Command Set' files for use with the
application 'Commander' (of use to 4th Dimension developers only).
Shareware: US$15 or one audio compact disk.
Golden Micro Solutions
P.O. Box 590, Blenheim, NEW ZEALAND
[Archived as /info-mac/text/notebook-maker.hqx; 132K]
Date: Wed, 18 May 1994 09:19:35 -0800
Subject: [*] PowerBook Insomnia v.3.2; Helps 'memory-effect' on batteries
This is the latest version of PowerBook Insomnia, a small utility used to
help against built up 'memory-effect' on batteries** for the PowerBook 100
& 200 series*.
The previous versions only supported the 100's series* or PowerBooks, this
version now supports the 200 series too.
This version of PowerBook Insomnia is freeware**
* Excluding the PowerBook 100 itself
** See the included 'ReadMe' text file for more details.
[Archived as /info-mac/cfg/powerbook-insomnia-32.hqx; 11K]
Date: Tue, 17 May 1994 01:26:38 -0800
Subject: [*] Right On Time 2.6
--========================_14427922==_
Right On Time is a personal time manager. It features a calendar, to-do
list, reminders (alarms), and even a menubar clock. It supports repeating
events, categories, digitized sound alarms, the new Speech Manager, and
more.
Right On Time contains the most-used features of commercial applications
such as Now Up To Date, First Things First, DateBook, etc., yet is very
easy to use, much smaller (both in disk space and RAM), does not require
any system extensions, and costs much less. If you are at all interested
in the various personal time managers, check this one out! Find out why
MacUser magazine said "Right On Time, which combines a calendar and an
event list, is probably the most elegant shareware to-do-list program
available right now" (Jan. 1994 issue).
Version 2.6 adds many new features and fixes some minor bugs. This version
is limited to 5 events, but is otherwise fully functional. The unlimited
version is shareware, $15.
John Covele, [email protected], [email protected]
Content-Type: application/mac-binhex40; name="Right_On_Time_2.6.sea"
[Archived as /info-mac/app/right-on-time-26-demo.hqx; 208K]
Date: Wed, 18 May 1994 02:24:17 +0000 ()
Subject: [*] ScriptRunner1.04; Run scripts
Here is a new version of ScriptRunner.
It is in util/diskfile or so...
[Archived as /info-mac/dev/script-runner-104.hqx; 432K]
Date: Wed, 18 May 1994 15:44:16 +0100
Subject: [*] SetupPartitions 1.0.3; Hard partition Apple SC disks
SetupPartitions is a neat utility that lets you create more
than one Macintosh partition on a hard disk formatted with
Apple HD SC Setup.
It _requires_ at least System 6.0.4 to run.
SetupPartitions lets you use true, "hard" partitions
(as opposed to "soft" partitions).
Quadra AV users will particularly appreciate SetupPartitions:
in fact, it seems that the only driver exploiting the new
awesome hardware capabilities of the AVs is the Apple one.
So you want to format with Apple HD SC Setup.
Since these days hard disks are pretty huge, you also want
to partition. So you want SetupPartitions.
No major code changes from 1.0.1, only a couple of fixes in
the registration code; user interface adjustments &
improved documentation.
Enjoy yourself and remember the US$10 shareware fee!
Fabrizio Oddone
[Archived as /info-mac/disk/setup-partitions-103.hqx; 28K]
Date: Mon, 16 May 94 10:35:13 EDT
Subject: [*] Slot Machine v1.0; a HyperCard based game
This is a HyperCard game based on the Las Vegas style slot machine (also
called the 'One-Armed Bandit'). It has animation and sound giving it all the
thrills of a real slot machine. Requires HyperCard 2.1 or later. Works best on
faster Macs.
Randy Vandermolen [[email protected]]
Software Engineering Institute
Carnegie Mellon University
[Archived as /info-mac/game/slot-machine-10-hc.hqx; 153K]
Date: Tue, 17 May 1994 16:56:00 -0400 (EDT)
Subject: [*] Solution for 'The Journeyman Project'
Dear Macintosh FTP archive adminstrator,
Enclosed with this message is a copy of my Walk-thru guide for
the CD ROM game 'The Journeyman Project'. Please place it in the
appropriate game or text directory.
Adam Schenker Department of Computer Science & Engineering
[email protected] University of South Florida
[Archived as /info-mac/game/com/the-journeyman-project-guide.txt; 15K]
Date: Wed, 18 May 1994 12:36:08 +0200
Subject: [*] Sounds Helper 11v1; Play sounds in background, rec long sounds
Hi !
Could you replace "SoundsHelper 1.1" by "SoundsHelper 1.1v1" ?
The program is attached to this mail.
Thanks very much.
[Archived as /info-mac/snd/util/sounds-helper-11v1.hqx; 117K]
Date: Wed, 18 May 1994 00:26:45 -0400
Subject: [*] speedometer-powerbook520sit.hqx; Blackbird performance
Here are Speedometer 3.23 machine records for the "BlackBird"
PowerBooks 520 and 520c. Unfortunately I couldn't test a 540
or 540c.
Enjoy!
Jeffrey
[Archived as /info-mac/cfg/speedometer-for-pb-520.hqx; 3K]
Date: Fri, 13 May 1994 10:24:56 -0800
Subject: [*] Speedometer 4.0.sea (Fat Binary)
I am not the author. I downloaded this from AOL. The following is the
README included in the archive.
This is version 4.0 of Speedometer. it supports the PowerMac in native mode
and adds a number of new features. Unfortunately, there may be bugs as
well. You should make a backup copy of any machine record files you want to
keep secure before you use them with the new version of the program. Please
send bug reports to [email protected].
-sb
[Archived as /info-mac/cfg/speedometer-40.hqx; 371K]
Date: Wed, 18 May 94 09:38:20 -0700
Subject: [*] Spheres!; place pipes, balls in the holes game
Here's Jonathan Wolf's shareware game "Spheres!", a place the pipes,
direct the balls, fill the holes, where's that piece, no not that one,
no not that one nonotthatoneAAAAAAGGGGGHHHHH!!!!! wild race to
complete the level. Lots of levels, lots of challenges. You'll go
nuts!
This game was originally released about two months ago, but seems to
have disappeared from Info Mac. (OK, OK, maybe I forgot to upload
it....) The game unpacks playable; registration gets you an unlock
code for higher levels.
[Archived as /info-mac/game/arc/spheres.hqx; 706K]
Date: Fri, 13 May 1994 21:05:52 -0400
Subject: [*] Strange Ways #9 for mac
This is issue 9 of Strange Ways, the only electronic magazine devotes to
the rock band KISS.
This is a stand alone document (created with DocMaker) and requires nothing
extra to run. All that is needed is a color Mac.
Inside this month's issue:
Tribute album news
KISS On Tour
in Texas
in Chicago
CD Discoveries
Unreleased KISS
Color Pictures
Readers' Poll Results
Digitized Samples
much, much more
Questions? Comments? Mail to: [email protected]
Enjoy
[Archived as /info-mac/per/strange-ways-9.hqx; 442K]
Date: Tue, 17 May 1994 22:12:33 -0400
Subject: [*] Symbionts 2.4.1; Detailed info on loaded extensions
Symbionts is an extension that monitors the startup process. Symbionts
displays the name and number of bytes of memory each system extension
allocates from the system heap. The name and number appear beneath the
extension's icon, and since the name is usually truncated, Symbionts also
displays it in the menu bar. Symbionts even shows the icons for those
extensions that don't normally reveal themselves.
Symbionts Control is a control panel that sets the preferences for the
Symbionts extension. It also allows the review of the information
collected by the Symbionts extension. Additionally, the control panel is
used to manage the loading of system extensions without having to dig
around in the System folder. Extension can be enabled and disabled simply
by double-clicking on the extension icon and name.
Version 2.4.1
* Startup Items panel now shows memory usage for Applications, Desk
Accessories, etc. that are still running when the control panel is opened.
* Oops, I left a debugger trap in. Pressing the Trash button would
produce unimplemented trap error or drop into the debugger.
* Fixed problem which caused name to overlay icon during startup if
'Show extension name below icon' is checked, but 'Show extension size below
icon' is not.
[Archived as /info-mac/cfg/symbionts-241.hqx; 114K]
Date: Tue, 17 May 1994 22:14:15 -0400
Subject: [*] Symbionts 2.4.1; Update -- info on loaded extensiosn
Updates Symbionts 2.3.3, 2.4b1, and 2.4 to 2.4.1
Version 2.4.1
icon' is not.
[Archived as /info-mac/cfg/symbionts-241-updt.hqx; 89K]
Date: Tue, 17 May 94 14:29:40 CDT
Subject: [*] Telnet2.6.1d1 Source Code
Several people have asked me for the NCSA Telnet 2.6 source code. The source
code for 2.6 is not available. However, the source code for 2.6.1d1 _is_
available.
Don't let the "d" scare you. The primary difference between the 2.6.1d1 source
and the 2.6 source is the addition of some macros and a few small changes so
the source code will compile native for the PowerMacintosh. The changes
are detailed in the readme file.
[Archived as /info-mac/dev/src/ncsa-mac-telnet-261d1-c.hqx; 871K]
Date: Mon, 16 May 1994 19:26:54 +0100
Subject: [*] Tiggr's Clock 1.0
Tiggr's Clock 1.0, for AfterDark
A friend of mine, called Tiggr, originally wrote this rather nice clock for his
NeXT machine. So he deserves the credit. This clock is an arc ranging from the
hour-hand to the minute-hand. I didn't look into Tiggr's source, but I figure
that with Display PostScript the code was much neater that mine, I use Regions
to create smooth drawing (instead of off-screen drawing) and the code is just
like a plate of spaghetti...
I contribute this module to Lloyd Wood, if it wasn't for him, I would have left
my compiler alone today...
Anyways, have fun! This is shareware.
History:
1.0: Initial release
Got a Mac? Got a screensaver? Read the Screensaver FAQ by Lloyd Wood!
Thanks to a name conflict it even mentiones my previous Screensaver called
'Trigo'. Check it out! :-)
pooh
internet:
snail mail:
Hoogstraat 214
5615 PX Eindhoven
The Netherlands
[Archived as /info-mac/gui/ad/tiggrs-clock-10.hqx; 8K]
Date: Tue, 17 May 94 6:29:00 PDT
Subject: [*] Timekeeper 3.1 demo; track time spent on projects
Timekeeper 3.1 from The PandaWare Company is an easy-to-use HyperCard-based
time tracking application. This new version offers an improved interface
over earlier versions.
PandaWare Timekeeper is for anybody who charges clients for their time. It
lets you keep track of projects you've worked on for different clients, and
how much you're charging them for each activity you perform on a project.
It offers extensive reporting, exporting and printing capabilities. Here
are some of the useful features you'll find:
* Lets you track time down to the tenth- or quarter-hour
(your choice)
* A virtually infinite number of clients, projects and
activities are accessible with a mouse click
* Lets you assign hourly rates to any activity
* Automatically sums your time and charges on every project
* Automatically creates summary reports for any project
* Automatically creates daily timesheet reports
* Data entry is easy -- just select items from lists
* Lets you customize the data you record on each project
* Lets you export data on projects to database, spreadsheet or
other applications for incorporation into your own billing
system
There are many other features waiting for you to discover. This Timekeeper
3.1 demo offers every function available in the full working version. It
tracks up to seven projects for up to 20 days.
The files in this archive have been found to be free of viruses by
Disinfectant 3.5.
[Archived as /info-mac/app/timekeeper-31-demo.hqx; 116K]
Date: Fri, 13 May 94 21:42:44 BST
Subject: [*] UnderWare 1.0->1.0.1 updater
Users of UnderWare, the desktop animation/textures/AfterDark-compatible
screensaver package, can update from version 1.0 to 1.0.1 with this updater.
See the included textfile for detailed information on the fixes and changes.
I am not affiliated with Bit Jugglers in any way. I have not been able to
test this updater, as I have UnderWare 1.0.1. Comments/questions to
-- L.
[Archived as /info-mac/gui/underware-10-101-updt.hqx; 216K]
Date: Sat, 14 May 1994 09:11:59 -0700
Subject: [*] UUParser 1.72
Description follows
UUParser 1.72 is now avaialble. This is a major upgrade to version 1.71,
with many fixes, and additional features.
UUParser is one of the easiest to use file strippers and
uuencoders/uudecoders available for the Mac. It support several different
encoding methods (mac->unix, unix->mac, AIFF->ULAW, AIFF->Linear), and is
the fastest decoder avaialbe for the Macintosh. It can operate fully in
the background (for unattended encoding/decoding of several files), and
lots more!
Here are some things you may want to know about UUParser:
UUParser 1.72 & 1.8 features
% Automatic stripping of header information from files "S"aved
from a usenet newsgroup.
% "Smart" uudecoding. Fully user configurable.
% uuencoding of AIFF (sound) files is now supported.
% uuencoding/decoding in PC, UNIX, and AIFF formats.
% User control over output file location.
% Join multiple text files for UUParsing & automatic decoding, from
the menu OR the Finder.
% Split any text file into multiple parts using the Split File function.
% User configurable preferences.
% Automatic scan of text files for anomalies.
% Drag & Drop supported via System 7.
% Parsing/uudecoding/encoding occurs in the background.
% Decodes/encodes/parses/splits/joins ANY SIZE FILE, regardless of memory!
% The FASTEST uudecoding/encoding available for the Mac!
% Many other new features added, with updated documentation!
*Version 1.72 is now the sharware version until further notice.
[Archived as /info-mac/cmp/uu-parser-172.hqx; 107K]
Date: Tue, 17 May 1994 18:28:27 -0700
Subject: [*] Word StdFile Color Icon Patch; Add color icons to file dialog
Here's a quick patch I put together for Microsoft Word 5.1a after I
got the new Apple System Update 3.0 for System 7.1. All this patch
does is adds 'dctb' resources to the Word application for the
Standard File Open and Save dialog boxes that Word uses.
I don't like patching my applications, but after seeing the cool new
small color icons in the Standard File dialogs, I had to have them
in Word! Since this worked so well, I decided to package it up and
share it with the rest of the world. The patch application was made
with ResCompare and a separate ResEdit file with just the new
resources is also included for those so inclined.
Complete documentation is enclosed. This software can be used and
distributed freely, but not for profit, provided all files are kept
intact and not modified. Although free, this is not public domain
and I retain the copyright to this software and documentation.
Geoff Walsh
[Archived as /info-mac/app/ms-word-stdfile-color-icons.hqx; 30K]
Date: Wed, 18 May 94 11:12:15 EDT
Subject: [*] xupdater-101v2.hqx; Update software Perspectives xcmd/xcmds
Subj: XUpdater 1.0.1v2
Software Perspectives - XUpdater 1.0.1v2
Xupdater is distributed to Software Perspectives customers
and online services to allow users to easily update existing
Software Perspectives XCMDs or XFCNs.
Updates are distributed in update modules which are utilized
by this utility.
This utility may not be distributed except with the permission
of Software Perspectives. Permission is given to the info-mac
archives to distribute this software online and on CD-ROM.
[Archived as /info-mac/card/xupdater-101v2.hqx; 86K]
Date: Thu, 19 May 1994 09:24:52 +0100 (BST)
Subject: (Q) Disk capacity limits - 80MB just ain't enough!
We would like to increase the disk storage capacity on a MacIIvx by installing
a second drive in the bay where the internal CD-ROM drive would normally go.
I think I read once that the maximum size of disk that a Mac can
address is 2GB, but I see adverts in Mac magazines for drives up to 3.5GB.
Would someone kindly clarify the situation.
By the way, is there a FAQ on buying and fitting hard drives?
Please reply to me directly.
Thanks in advance,
Greg Birch
Southampton, U.K.
Date: Wed, 18 May 1994 19:40:21 -0600 (CDT)
Subject: [FWD] [D[D[DApparent Bug in System Update 3.0
On Wed, 18 May 94 08:27:26 EDT [email protected] said:
>Loaded System Update 3.0 in my Mac IIfx (20 meg RAM, no internal HD,
>boot from dual 150 bernoulli) to update System 7 Pro. Printed a file in
>MS Word that uses Adobe's AGaramond Semibold and Semibolditalic True
>Type fonts. File prints with bitmap jaggies as if ATM were not
>installed. Same file printed two days earlier with smooth crisp
>output. Same file printed today with another bootdisk that did not have
>System Update 3.0 installed was also smooth and crisp. Only difference
>in system configuration with the before/after prints is System Update
>3.0. Other boot disk has essentially the same System 7 Pro folder as
>the primary boot disk before its update.
First, to clarify: Adobe Garamond is a Type 1 PostScript typeface, not
TrueType. In fact, Adobe does not sell ANY TrueType fonts.
>I don't know the cause but it appears that something in the System
>Update 3.0 is interfering with true type font smoothing. I don't
>understand ATM well enough to know whether it is involved, but its
>configuration is the same on both disks, and it is active.
>Using ATM ver. 2.0.3 and LaserWriter driver ver. 7.0.
First, call Adobe and get an upgrade to ATM 3.6 Version 2.0.3 doesn't
like Apple's new Fonts folder and the update may cause the Mac to stop
looking for fonts in the Extensions folder. Second, LaserWriter 7.0 is
fundamentally wonky, and should have been replaced by a later version,
such as 7.1.x by the System 7 Pro installer. You may even want to
consider LaserWriter/PSPrinter 8.1.1
Another possibility is that your font may have gotten broken somewhere in
the process. reinstall both screen and printer fonts from the original
disk and see if it gets better.
--Andrew Vernon ([email protected])
Date: Thu, 19 May 94 10:18:48 +0100
Subject: Accellerators + Frame Buffers for SE
Hello all, a quick question
Are there any combined accelerators + mono frame buffers for my SE.
Ideally I would like 68030 based with a resolution of around 1280x1024.
I would like to get a faster Mac, but I have no use for color, fancy sound,
and movies. All I do is wordprocessing, and spreadsheets, with output to
a black and white printer.
Many Thanks In Advance
Kevan Heydon
Date: Wed, 18 May 1994 20:51:23 -0400
Subject: An alternative to MountImage1.2b2
On Wed, 18 May 1994 08:53:40 -0500, Douglas Wyman wrote:
>There is a piece of unauthorized and dangerous code
>which frequently gets transferred from other archives
>to info-mac like a staph infection from a carrier to a
>salad bar. It appears that someone has, again,
>obtained a copy of the control panel MountImage1.2b2 and
>uploaded it "for our enjoyment".
I recently downloaded "MungeImage" (an application) from the archives. I
haven't tested it extensively, and it is limited to mounting one image at a
time, but it seems to work fine. I trust its not afflicted with the
corrupting bug?
Date: Thu, 19 May 1994 00:02:35 -0700
Subject: Application monitor?
Is there a utility available that will monitor time spent in various
applications, record that information, and prepare a periodic summary? I'm
interested in keeping track of usage for tax purposes, and hope to find
a public utility to do just that.
Thanks for any suggestions.
Rod Harl
U.C. Berkeley
Date: Wed, 18 May 1994 13:59:16 -0400
Subject: Book available for MPW? (A)
[email protected] (Alun J. Carr) writes:
>Is there a book available which provides a simple introduction to the MPW
>shell? Apple's manuals are intimidating to say the least, and I would like
>to be able to do more with the MPW shell, other than use the canned
>commands that come with my FORTRAN compiler.
I have one such book:
Joel West, Programming with Macintosh Programmers Workshop, Bantam, ISBN
0-553-34436-3, $29.95.
Date: Wed, 18 May 1994 17:57:48 -0700
Subject: Calendar
I am looking for a way to generate a month calendar that would have a
listing of events on it. This information would be basicly something like
"9:00am Robi's Donuts Expert ride". I would also like to have a title
(club name) and some contact information at the bottom. This would be
printed on a 8.5"*11" paper. I have ClarisWorks. But have easy access to
Filemakerpro, Freehand, Pagemaker, Excel and a few others but can not
recall them.
I would like this to be as easy as posible. But I could just draw one up
and manualy make it. But I would prefer at least some form of automation.
At least to create the calendar dates and borders.
Thanks
Mark
Date: Wed, 18 May 1994 11:57:15 -0400 (EDT)
Subject: CD-Rom Setup
In Info-Mac Digest v12 #75
[email protected] wrote:
>I have a Centris 610 running System 7.1 with a built in CAI CD-ROM.
>I've had 3 problems with the new CD-ROM software.
>1. If I try to install it, the installer crashes with an application error.
>2. If I manually try to copy the files to my system folder, I get all
> sorts of weird behaviour. System locks up...screen clears...
>3. If I try to use the application, I get a message that the application
> needs to be made bigger. If I do so with Get Info, the
> min size goes to 0 and the preferred size goes to 4 MBytes.
> Also, the app size changes to ~ 2 Mbytes.
>Any thoughts?
Well, I can't tell you whether or not the software will work with your CD
Rom (NEC's, for instance, seem to require a special driver), but I can
confirm the Centris Problems.
I have a Centris650 16/230, and have always had to install the CD Rom
software manually...the installer has never worked properly for me. If you do
this, make sure that you remove ALL vestiges of the old CD-Rom driver, as
it may crash the machine. This includes foreign file system parts and
all...they have compacted the software and it includes fewer extensions.
What a pain. By the way, the latest Cd-Rom software from Apple is 5.0.1
Has any other Centris user had problems with the installer?
-Edward Palazzo-
Technical User Consultant
Macintosh Labs at Jackson
Tufts University
Date: Thu, 19 May 94 09:55:33 JST
Subject: DataScan equivalent [A]
I too bought DataScan back when it came out. There is a freeware
equivalent software called DataThief (which is on Sumex I believe) that you
should take a look at. It has automatic digitatization as well. It's
resolution is limited to screen resolution and thus the maximum number of
points is limited, but usually that is not a serious limitation.
Dr. Paul Fons [email protected]
Date: Thu, 19 May 1994 20:46:17 +0300
Subject: Email for Daynafile makers (q)
Hi,
Does anyone have an Email address for the makers of Daynafile. I am
looking for the latest extension for their drive. I am using 4.1 and it
does not seem to be compatible with the Quadra 605.
Do they have an FTP site?
Thank you,
David
Date: Thu, 19 May 94 17:00:00 +0200
Subject: File Server Shut Down ???
How can I shut down AppleShare file server software on my PowerPC 7100
automatically.
I have the Power ON/OFF control panel which is great, but there is a
box coming up which notifies you of the time remaining until shut down.
This box has an OK button which has to be pressed, our server has
no screen and I would like it to shut down automatically.
The box is also no alert box that's why I can not use the
OkeyDokey controlpanel.
Any help would be appreciated.
Rolf
_______________________________________________________________________________
___/\_ | Rolf Kocherhans Internet : [email protected]
Date: Wed, 18 May 1994 23:53:09 -0400 (EDT)
Subject: GL viewer for the mac
Does anyone know of a gl movie viewer for the macintosh?
Date: Wed, 18 May 1994 22:36:00 -0500 (EST)
Subject: Info-Mac Digest V12 #75
MAC IIci Microphone wanted
Where can I get a microphone for a MAC IIci and for
how much? The unit at home is from work and the original
got lost or was never with it.
Thanks
-Sanjay Kumar
Date: Wed, 18 May 1994 14:16:28 -0800
Subject: InterSLIP
I am trying to get InterSLIP to work, but am having difficulties.
Can anybody provide info on how to write a gateway script for InterSLIP,
and where can I get an ARA script for the US Robotics Sportster 14,400 Mac
& Fax. Any input will be much appreciated. Thanks.
Pearly Lee
Date: Wed, 18 May 1994 16:22:03 GMT
Subject: Invisible name
Does anyone out there know if it is possible to hide the name of a
folder/file so that it is represented only by it's icon?
Kenneth Pettersson Phone: +46 480 808 45
Telia AB Fax: +46 480 277 69
Box 814 email: [email protected]
S-391 28 KALMAR
SWEDEN
Date: Thu, 19 May 1994 17:58:58 PDT
Subject: Laserwriter NT Repair
I have done EXACTLY what you ask (I think...)
Here's the scoop:
There is a big black plastic piece kind of on top with three screws in it.
These screws are phillips, and are easy to get to. When I first examined
the printer, it looks like the plastic part is actually part of a bigger
assembly, but it is not. You must completely remove the three screws, this
piece will come out, and you can get to your label.
I tried to take more of the printer apart, and let me tell you: It's
impossible to do without more information... I have taken apart Mac Plus',
SE's, SE/30's, a million (ok, maybe not a MILLION) Mac II's, monitors,
keyboards (got stumped by the adjustable), the Pro 810, the Pro 630 etc.
and have never (except for the adjustable keyboard) been stumped like I was
with the NT. There are a million screws and tabs etc.
However, I recently aquired the service source CD, which has diagrams etc.
of this printer. I haven't tried to take one apart yet with their
directions, but they seem to be pretty complete... If you need to do more,
let me know and I'll try to help.
Let me know if this helps!
Joel
Date: Wed, 18 May 1994 19:52 EST
Subject: Mosaic (Q)
Dear Netters,
Does someone have documentation from Mosaic? Where can it be found through
FTP or Gopher? I would like to find a version that works on a 9600 BAUD Hayes
compatible modem Macintosh LC System 7.0.0, to connect to a SunOS BBS with
Internet access. I would to find out more about Mosaic to see if it fits into
what I already do on Internet.
Thank you.
Sincerely,
Date: Wed, 18 May 1994 20:51:19 -0400
Subject: NEC SW 2 90 toner cartridges
On Tue, 17 May 1994 15:13:53 -0400 (EDT), William P. Krauthammer wrote:
>I know this is a bit off-topic but can anyone recommend a reputable mail order
>house that sells replacement toner cartridges for an NEC SilentWriter 2 90?
Without checking specifically, I suspect you'll find one at MEI in Ohio
1-800-634-3478. I generally find they beat everyone's prices on supplies
(disks, toner cardridges, disk storage boxes, etc.).
The other low price supplier that usually can manage to find appropriate
supplies is Elek-Tek in Chicago 1-800-395-1000.
I've had excellent experience with both companies.
Date: Thu, 19 May 1994 08:22:57 -0500 (EST)
Subject: Networking Problems
I am pretty new to this stuff, and do not know the proceedures for searching
back Q's & A's. Anyway, we have a lab consisiting of various Macs on a Novell
3.11 network. We cannot run Wordperfect (2.1) or PageMaker (5.0) on the
network. Currently, we load 10 copies on all of the drives. Those of you who
are network administrators can appreciate the problems with this.
PageMaker told us we would have to get a program like "KeyServer" to run it on
the net. I've contacted the vendor, Sasafras Software of Hanover, NH. to get
more information on it.
So, my questions are:
1) Has anyone else encountered this type of problem?
2) Has anyone else used this KeyServer software? What were your results?
3) Any additional tricks we need to try?
As a point of significance, I am "crossing over" to the Mac environment from
IBM-compatible PC networks. Please pardon any ignorance I am showing now or in
my replies to you.
Thank you for your help.
Please respond by private e-mail to [email protected]
Rob Gallini, User Support Coordinator, Albion College.
Date: Thu, 19 May 1994 12:35:07 +0200
Subject: NisusWriter 4.0
Hello !
I saw a posting a few days ago asking about the new version of
Nisus. I got that version a while ago for Beta testing and I think it might
be a good idea to share some of the new features with info-mac users. Note
that this is a partial list of the features I found, I haven't worked with
the package enough time to find everything since the version I got is too
buggy (for my taste).
The first thing you'll notice is that it requires more memory. This
fat application (3.1MB of disk space - but that's probably because it's a
debugging version) must have a large 3.5MB minimum partition to load, and
since the tables and equations are done by external modules expect the
memory demand to go even higher (600K for the tables maker for example). I
think this means no more LCII 4/80 equipped people working on Nisus (and
this is the common case here). As to speed, I didn't check that but on my
950 it seems quite like the Old version speed.
At first site, everything is now in a cool 3D look. The window has
been rearranged a bit - on the upper part there's only control on the ruler
settings, while the "show rulers" moved down to the lower left corner of
the document. On that corner you can also find an icon that pops up the
whole "show" sub-menu and another one that pops up the "set clipboard"
sub-menu, making the clipboard switching much more useful. Besides that
there's also an icon that enables you to switch between editing the
document, the headers/footers and the footnotes. The top of the vertical
scroll bar is still used for working modes. You have the info bar, the
regular ruler mode, the graphical layer, the page layout and the all new
multimedia layer (which I will explain later).
The menus changed a lot. There's no "Format" menu - instead some of
the features moved to the "Tools" menu and the others, along with some new
options, were gathered into an "Insert" menu. I think all the dialog boxes
changed - all the model DBs are still model, but they now have a title-bar
that can be used to move them around the screen. Most of the DBs have been
rearranged and the global idea is that it looks much better.
Most noticeable new menu features:
* The File menu has an "Open Special" sub-menu that stores the last
recently used files and some user definable files ("Essential Files"). A
"Mail" sub-menu is also there to support AOCE (didn't try it, though).
* The Edit menu now has a "Publish & Subscribe" sub-menu (which wasn't
there is the regular Nisus edition we had) which supports all the regular
options. A convert sub-menu has been added to allow all the Lower/Upper
case conversions you might want.
The "Tools" and the new "Insert" menu (formally "Format") has
changed much. It seems (IMHO) that the options are now arranged much better
(like the fact that "Synch. Scroll" is now under the Windows sub-menu
rather than the Editing).
* The index and contents are now found under sub-menus in the Tools menu.
The contents hasn't changed much, but the index has many new features,
including HyperLinks which allows you to jump to the right place in the
text from the index.
* The Macros sub-menu has new "Do Frontier" command. The company claims
that AppleScript support is on its' way, too.
* The Display sub-menu now has a DB for editing all the window display
attributes and also line numbering formats.
* The insert sub-menu has a "Table" and "Equations" options. The tables are
generated by Tycho, which is a real excellent table maker. The Equations
are done with MathType which is, IMHO, one of the best of its' kind. Both
are supplied with Nisus. The insertion is in the OLE-like format: The menu
option launches the application, you edit the object and when you close the
window it is automatically inserted into the document. The next time you'll
double-click the object, the application will launch again and a window
containing the object will open so you can edit the object. Again, when you
close the window the object will be automatically updated in the document.
As I said before, this feature requires another applications to
run, so it will consume more memory. This object embedding technology is
nice, but it seems that a built-in tables option would be more comfortable.
On the other hand, Tycho runs circles around the tables in Word, for
example.
* The insert menu also has "QuickTime" option. Also the insertion of
graphics into the text layer is now called "Character Graphic" to avoid the
confusions between graphic insertion into the graphic layer and graphic
insertion into the text layer.
* A whole new numbering sub-menu has been added. The numbering is for
chapters, sections, subsections, sub-subsections, Figures, Tables,
Equations and 6 more user definable. In order to create a new number you
choose Insert->Numbering->the type of numbers you want. All types of
numbers are configureable so you can change the title, units and everything
else there is to change. It seems that they've done an excellent work on
this one.
* The insert date, time and document name are all under a "Variable"
sub-menu with the date/time format setting.
* The Style menu now has a Format sub-menu that includes formats which are
not styles like "Keep in the same line" and "Reverse". There's also a
"Gloss" option that let's you add a small super-script copy of the selected
text. The Format option is also added to the Style Sheets - enabling
formats like "Keep on the same page", "Contents" and "Hyphenate".
* The Graphics menu now has a nudging and Grid options.
The most noticeable graphic option is color. You can select a color
for lines and fills. There's also a new object overlapping options like -
add, subtract and blend.
There's a new "Sound" layer which is used for voice annotations and
speech (requires MacinTalk). When you record a sound it appears as a small
icon in the text. When you're in the sound bar mode you can still edit
text. The sound bar has the following options:
* A pop-up menu for global sound set and the sound that is currently
selected. This enables you to name the sounds you record and jump to them
in order to play them.
* A tape recorder buttons: Rec, Play, Pause & Stop.
* A speech button that "talks" the selection/document.
* A volume control.
There's also a new "Sound" menu when this bar is activated. It
includes:
* Sound catalog - lets you catalog the document sound by sets and play or
jump to any sound in any set (the sets are available from a pop-up menu in
the bar).
* Recorded sound quality & compression control.
* Voice settings for MacinTalk/PlainTalk.
* Playback & record options. You can record on words, sentences, etc. You
can set the activation of the recording by manually, by a key or by simply
voice activation (setting the voice activation/deactivation levels in the
voice quality DB).
I didn't get to check all those features since I find the interface
a little awkward and I didn't have the manuals (since there were no manuals
yet).
I think this covers most of the new features in the new Nisus. I'm
sure I missed some, maybe even some heavy options, but that's probably
because I didn't work with it much.
I don't know when this product is going to be released, but I now I
have a beta from march and I know that there are still problems with the
product so it might take it a little longer to come out. If you have any
other questions I'll be glad to answer them.
BTW, I'm in no way connected with Nisus Software. The opinions expressed
here are mine.
Zviki Cohen
Zviki Cohen
Dept. of Education in Technology & Science
Macintosh Technion - Israel Institute of Technology
Development & Consulting Haifa, Israel
E-mail: [email protected]
Talk & Finger: [email protected]
"No more war, no more blood shed"
Date: Thu, 19 May 94 13:20:07 -0400
Subject: PB100 Battery lifetime?
I have a PB100, owned it less than 2 years, I have hardly used it as a
portable in all that time. Yet the battery seems to no longer hold any
charge. Ie
if it sits for a couple of days it won't even boot without being plugged
in. What is the standard life for the battery, or might I have a bigger
problem? It seems to work fine when plugged in.....and the battery does charge
according to the Battery application...
thanks
STeve
Date: Wed, 18 May 1994 10:03:27 -0800 (PST)
Subject: Power User CD-ROM
Does anyone out there have any experience with the Power
User CD-ROM drive?
This drive is sold by MacWarehouse for $199, and is supposed
to be double-speed (300k/sec) and Photo-CD compatible with an
access speed of 370 Ms.
This seems like a good price for this type of CD-ROM drive,
especially compared to Apple's $399 model.
Is this drive worth getting? Are there any compatibility
problems with any of the current crop of CD-ROM-based games?
I'd appreciate any informationn this drive - positive or negative.
Thanks, Frank Ripp [email protected]
Date: Wed, 18 May 1994 19:58:12 +0200
Subject: Printer Selection without Chooser (R)
Tom Wilson (Tom Wilson) asked:
>What I'd really like to see is a a print dialog box that has the
>AppleShare Zone and Available Printer window so you could select where
>you want the output to go each time you issue a print command. Default
>would always be the one selected in Chooser.
I don't know if it works in a multi-zone environment, but you can try
PrintChoice, a shareware found on sumex and elsewhere.
PrintChoice puts a menu item on the first line of the Apple Menu with
a sub-menu list of all your pre-defined printers. Just select the one
you like to use from there - no need to go to the chooser.
Greetings, Christian.
Date: Wed, 18 May 1994 12:10:43 -0700
Subject: problems with System update 3.0 (C)
> well i just installed the sys update 3.0 on my powermac 6100/80 and now
> it crashes out whenever I tell it to EMPTY TRASH..
It works just fine on my 6100/60AV. From reading numerous posts in
newsgroups, I've noticed that the complaints, not to my surprise, have come
>From PowerMac owners who decided to increase the clock-speed of their CPUs.
-=-=- Robert Otani / Tempe, Arizona / [email protected] -=-=-
Date: Wed, 18 May 1994 10:40:40 -0500
Subject: Problem with ZTerm
Hello,
I am having problems consistently while quitting from Zterm on my LCIII.
The program works great except when I try and use the 'Command-Q' keyboard
shortcut to quit. This hangs up the whole machine, and the only way out is
to do a force-quit. (Command/Option/Escape). Has anyone else had this
problem? I've tried a fresh copy of Zterm, no luck there, and reinstalled
the System, etc.
Does anyone know how to help?
Kevin Thompson
Date: Wed, 18 May 1994 11:36:27 -0800
From: [email protected] (Kee Nethery +1 510 843 6140)
Subject: Quadra 605 on an inverter (A)
>I purchased a Quadra 605 to leave there permanently. To my great surprise,
>it does not power up when connected to my inverter (DC to AC) on my solar
>system. When I called Apple Technical support they informed me that this
>problem had been reported previously and they had no suggestions for cures.
Most of these Macs have switching power supplies and they should be able to
eat just about any kind of power input. Maybe the spikes from the SCRs on
your inverter are causing a problem with the switching power supply control
circuitry. The solution might be to smooth the spikes. You could try a
better quality inverter for use with just the Mac, get a UPS that does line
conditioning or get a 1 to 1 isolation transformer that will tend to smooth
out your sine wave from the inverter.
If you wish, I have a scope you could borrow to monitor your supply voltage
and see what is going into your Mac.
Located in Berkeley,
Kee Nethery
Date: Thu, 19 May 94 10:32 BST-1
Subject: Re-MountImage1.2b2.warning
>From Pindar user Ian McCall
Subject: Time:
9:26 am
OFFICE MEMO Re:MountImage1.2b2.warning Date:
19/5/94
Since I've now been warned about v1.2b2, what is the latest
acceptable version?
Cheers,
Ian
Please make 'Attn:Ian McCall' the first line of your reply
(not the subject) to ensure automatic forwarding to the correct
Pindar user.
Date: Wed, 18 May 94 09:06:24 MDT
Subject: Record Button
System Update 3.0 installed an extension called "Record Button." I haven't
found any description of it in the docs. Anyone know what it does? I've
been having a conflict since I installed this update and am trying to track
down the problem.
Roger
[email protected] NIST/Boulder, CO
phone 303-497-3037 fax 303-497-7828
Date: 18 May 1994 13:55:09 -0800 (PST)
From: "NAME \"Jan Zlendich, CSUF Mission Viejo Campus\""
Subject: Soft-PC and MS-DOS Kermit
Is anyone out there using SoftPC with Windows able to use MS-Kermit
with it? I have a Centris 610 with 20 megs of RAM. Am connected through
the Mac's modem port to a campus-wide network that I use to connect
to our campus VAX computer. When I use MS-Kermit on a PC, I type
c and immediately see the network's menu. When I use MS-Kermit on the
Mac I get the following error message: divide overflow. I have a
feeling that that I am doing something stupid and would appreciate
any available help from those of you who (unlike me) know what you
are doing. Thanks in advance for any much-needed help.
Jan Zlendich ([email protected])
California State University, Fullerton
Date: Wed, 18 May 1994 11:34:00 -0500 (EST)
Subject: SuperATM Conflicts with Network Connection? Help!
I would appreciate some help with the following problem:
A few weeks ago, we connected my Mac IIci to a Token Ring network using the
Apple 4/16MB Token Ring card and Apple's own Token Ring driver software. We
also installed MacTCP and the other networking goodies we needed. When I
tried to use my new network connection, I discovered that the Network control
panel had been corrupted, and the Token Ring control panel couldn't "see" the
Token Ring card. As a result, no networking.
Using a (long!) process of elimination, I found that I had to de-install ATM
3.6 (SuperATM) and re-install all the networking software to get everything
to work. Just turning off font substitution, or turning off SuperATM in the
control panel, didn't help. Without SuperATM, my network connection works
just dandy.
I finally installed an older version of ATM (2.0.3), which seems to behave
itself just fine, but I would like to go back to SuperATM. However, this
network connection is more important.
I have vague recollections of reading about network problems caused by
SuperATM's polling a network for illegal copies of itself. Anyone have
additional details?
Any advice or additional information would be much appreciated. I've had no
success getting any answers out of Adobe thus far.
Thanks in advance for any help! Please respond directly to the e-mail
address below, and I'll summarize for the net if there's sufficient interest.
--Larry
Date: Wed, 18 May 94 23:38:16 -0400
Subject: SURGE ARREST
What's the scoop on surge protectors these days? Do the more
expensive ones really provide better protection, or would I
be wasting my money? Jack O'Leary
I just bought a APC Surge Arrest. The product is very well built. It includes a
plug for my modem. They have eveything from low cost models to very expensive
battery systems. They have a catalog that you can get at (800) 800-4APC in
U.S.
In Canada, the product is sold by MISCO in Ontario at a very good price.
For example, suggested retail price U.S. for my product is 59.95$ and I paid
68$
canadian. Shipping is low cost. (800) 661-6472 in Canada. They have a fine
catalog too covering every possible accessories. They even speak French!
With the summer coming and all the electrical storms I think I did a good
investment. Also there is a protection up to 25000$ U.S. if a system plugged on
a APC Surge Arrest or any other specified APC product, is burned. The warranty
is very specific and you have to read it to know exactly what you get.
Louis [email protected]
Date: Thu, 19 May 1994 11:40:09 +0100
Subject: Unable to access mailto: links using NCSA Mosaic
When I click on a "mailto:" link in NCSA Mosaic (version 1.0.3), I receive
an error message that Mosaic cannot access the document. Does anyone know
if Mosaic supports mailto: links ?
Thanks in Advance
Hans de Wolf - Fokker Space & System B.V.- PO Box 32070, 2303 DB Leiden, NL
[email protected] Tel. +31 (0)71 245878 Fax +31 (0)71 245835
Date: Thu, 19 May 1994 06:42:56 -0600
Subject: Wanted: Drag & Drop text encryption (A)
>My requirements are as follows.
> - I would like to be able to compose a plain text document in teachtext,
>save it, then drop it onto the encryption application.
> - the encryption app. should prompt for an encyption key then create an
>encrypyted version of the document and save it or possibly copy it to the
>clipboard.
> - Decryption should be a matter of dropping the document, being prompted
for
>a key, saving the result and quitting.
David,
For starters, try Enigma 2.3.2 It does what you want and more. It
should be available at most big mac ftp sites (like sumex - email me if you
can't find it - I'll send you archie search results... ) It is freeware,
and implements a limited version of DES. A full DES version is available
for $15 - but ONLY within the U.S. (Encryption software above a certain
level is considered munitions and is illegal to export)
Mike
Date: Thu, 19 May 1994 12:29:24 -0400
Subject: Why is DayStar PPC card so expensive? (R)
>It seems to me that DayStar's PPC upgrade card is priced unreasonably to
>about the same extent that their '040 and '030 cards are.
Yes. Anyone have comments on the MacUpgrade MicroMac $99 25Mhz+68881
PDS upgrades to older 16Mhz boxes (wrt compatibility & performance) ?
Date: Thu, 19 May 1994 12:39:22 -0400
From: [email protected] (Bill Barnett-Interdepartmental Labs)
Subject: Yamaha Speaker Problems (Q)
Just tried out some Yamaha YST-M10 speakers on my Mac, expecting
great things. Every time I hook them up, the left speaker keeps cutting
out. I cannot believe it is the cable; fiddling with the plugs (which run
in and out of the right speaker) cuts the left side in and out. I have
just tried my 3rd pair (having sent the first 2 pair back). Upshot is that
I cannot get stereo out of these stereo speakers.
Has anyone else had similar problems with these speakers?
Can anyone recommend stereo speakers at about the same price range
($80) that deliver acceptable sound and actually work?
Many thanks in advance...
-Bill Barnett ([email protected]) American Museum of Natural History, The City.
Date: Wed, 18 May 1994 16:20:11 -0400
I have two queries.
Query 1:
Very recently I was able to get my hands on the Colour StyleWriter for part
of a day.
First I connected it directly to my PowerMac, via the printer port, and
played with it. I printed a number of pictures using SuperPaint and
IntelliDraw. I was very impressed with the results, but bear in mind that
this was my first exposure to a colour printer! This initial test took
about an hour.
Then I connected it to an SE30, again via the printer port, in another
office. Again it worked fine when run from the SE30 directly. However when
I went back into my office and tried to print from my PowerMac, using the
advertised printer sharing facility, it was no go. I spent the rest of the
afternoon unsuccessfully trying to figure out what was wrong.
When my friendly dealer representative arrived to retrieve the machine, I
recounted my tale of woe, and he promised to check into it. Earlier today I
was provided with the gen.
First, the sharing facility only works with LocalTalk. My impeccable source
tells me that a new version of the driver, which is available on AppleLink
and which he will download for my benefit soon, allows the sharing facility
to work with EtherTalk. In the course of this conversation I also learned
some other interesting (at least to me) pieces of information: The
StyleWriter II and the colour StyleWriter are directly (ie. without
recourse to the Grey sharing device) usable on a LocalTalk Network. This
last was a surprise to me, since I recall some exchanges on the net
bemoaning some aspects of the performance of the Grey sharing software. I
also specifically asked whether this meant that I could access the printer
on EtherNet using EtherPrint, or the like, and was told that that I could.
Could someone confirm this?
Query 2:
I am considering acquiring one of those dinky label printers for use by our
office. As with the colour printer above I would need to be able to put it
on the network to be accessed by all. I am just beginning to look into what
is available and have already discovered that most of the three or four
choices available are not even LocalTalk compatible, and their prices are
certainly not dinky.
I would appreciate hearing about any experiences with one or more of these
devices.
Thanks.
Charles A. Patrick ([email protected])
International and Professional Relations Division
Statistics Canada
Ottawa, ON K1A 0T6
CANADA
Tel: 613.951.8920 FAX: 613.951.1231
